Epsilon Delta proof of a 2variable limit. Is my proof valid?
AutumnWater
Use the epsilon delta definition to show that lim(x,y) -> (0,0) (x*y^3)/(x^2 + 2y^2) = 0
sqrt(x^2) = |x| <= sqrt(x^2+y^2) ==> |x|/sqrt(x^2+y^2) <= 1 ==> |x|/(x^2+2y^2)?
This limit is true IFF for all values of epsilon > 0, there exists a delta such that:
0<sqrt(x^2+y^2)<delta ==> |(x*y^3)/(x^2+2y^2)| < epsilon
When checking my answers, I'm stuck at this step:
Can: |x|/sqrt(x^2+2y^2) <= 1 imply that |x|/(x^2+2y^2) will also be <= 1?
I'm skeptical as it seems wrong, but if this step holds, then the rest of my proof can be as follows:
(|x|/(x^2+2y^2))*|y^3| <= |y^3| = |(y^2)^(3/2)| <= (x^2 + y^2 ) ^ (3/2) < (delta)^3
thus
let delta = (epsilon)^(1/3) and we get:
sqrt(x^2+y^2)<epsilon^(1/3) ==> (x^2+y^2)^(3/2) < epsilon ==> (y^2)^(3/2) = y^3 < (x^2+y^2)^(3/2) < epsilon;
Since |x|/(x^2+2y^2) <= 1, (|x|/(x^2+2y^2)) * |y^3| < |y^3| < epsilon;
and we have f(x) < epsilon.
on Phys.org
thus
No. (Take x=0.5 and y=0.1 for example)
Hint: ##\frac{1}{x²+2y²}\leq \frac{1}{2y²}##
thanks, I'll go review my polar coordinates chapters first :P
That works too. :oldsmile:
so we have: f(x,y) = (xy^3)/(x^2+2y^2)
since 1/(x^2+2y^2) <= 1/2y^2
f(x,y) <= (xy^3)/2y^2 where (xy^3)/2y^2 = xy/2 = p^2 sin(2theta) / 4 (let that = g(p,theta))
since sin(2theta) is between [-1, 1],
-p^2/4 <= g(p,theta) <= p^2/4
and f(x,y) is <= g(p,theta)
does that mean I should set delta = 2sqrt(epsilon) here then?
We need 0<p<delta to imply g(p,theta)< epsilon, since we know g(p,theta)< p^2/4, if we set delta = 2sqrt(epsilon), 0<p<2sqrt(epsilon) ==> (p^2)/4 < epsilon, then it works?
So in the end we have:
1) 0<sqrt(x^2+y^2)<delta where sqrt(x^2+y^2) = p, set delta = 2sqrt(epsilon)
2) |f(x)| <= g(p,theta) <= p^2/4 < epsilon
since p<2sqrt(epsilon) ==> (p^2/4) < epsilon
we have a connection between 1) and 2) here.
I assume you mean 1/(2y2) on the right hand side.
1/(x^2+2y^2) ≤ 1/(2y2) implies that x2 ≥ y2. Did you really mean that?
If you're going to change this to polar coordinates, Nothing is more convenient to convert than x2 + y2 .
After all, x2 + y2 = r2 .
Added in Edit:
Somehow I missed seeing the coefficient of 2 on the y2 in the denominator, so ignore this, which it seems you have. (thankfully!)
yes I meant 1/(x^2+2y^2) <= 1/(2y^2) implies (xy^3)/(x^2+2y^2) <= (xy^3)/(2y^2)
You need some absolute value signs: the inequality is reversed when [itex]xy < 0[/itex].
Ok thanks.
Here I got 2 different deltas, would it be safe to say both are correct, only one is even more closer than the other one?
If looking at the initial equation directly:
We have:
$$|(xy^3)/(x^2+2y^2)| = [(p^2*(sin(theta))^2*sin(2theta))/2(1+(sin(theta))^2)] <= (p^2)/2 < epsilon$$
so we set delta = sqrt(2epsilon)
If looking at the equations from the perspective of $$|xy^3|/2y^2$$: then delta's $$2sqrt(epsilon)$$ according to previous post.
You could make it a lot simpler by substituting ##y=z/\sqrt 2## before going polar.
would it? whilst there will be a coefficient of $$1/(2^{3/2})$$ on the numerator of the f(x) only when doing the z substitution, the equation for delta wouldn't be p=sqrt(x^2 + y^2) anymore, instead it would turn out to be sqrt(x^2 + (z^2)/2) wouldn't it?
so $$|(x^{2} + (z^{2})/2))^{1/2}| <= delta$$ needs to imply $$|((xz^{3})/(2^{3/2}) / (x^{2} + z^{2})| < epsilon $$ ?
in polar form that would amount to:
sqrt(5p^2/4) < delta needs to imply that p^2/2 < epsilon
(sorry, I will get a hang of latex codes soon)
So make delta a bit smaller for the given epsilon.
oops, the p^2/2 < epsilon earlier didn't include the $$1/(2^{3/2})$$
so if it was $$(1/(2^{3/2})) * (p^2/2) < epsilon ==> p^2/2 < 2sqrt(2)epsilon ==> p < 2 (2^{1/4})\sqrt(epsilon)$$
and $$\sqrt(5)p/2 < delta ==> p < 2(delta)/\sqrt(5)$$
make ps equal, and I got $$\sqrt(5)(2^{1/4})\sqrt(epsilon) = delta$$ which is about 2.659 times $$\sqrt(epsilon)$$, bigger than the other two...
so far I've had: $$\sqrt(2epsilon)$$, $$2\sqrt(epsilon)$$, and now $$(2^{1/4})\sqrt(5epsilon)$$
  • · Replies 31 ·
  • · Replies 27 ·
