Equal Speeds at y = 0 for Frictionless Slides?
The discussion revolves around a physics problem involving four frictionless slides defined by different equations. Participants are tasked with determining the relationship between the speeds of objects sliding down these slides when they reach y = 0, starting from the same height h.
  • Participants explore the concept of speed and acceleration, questioning whether the slides lead to different speeds at the bottom. They discuss the application of conservation of mechanical energy to derive speed values and express confusion regarding the equations representing the slides.
Some participants have attempted calculations using conservation of energy, but discrepancies in their results have led to further questioning. There is a recognition that starting from the same height implies equal initial potential energy, which should affect the final kinetic energy and speed.
Participants are grappling with the definitions and implications of the equations for the slides, particularly regarding their shapes and how they influence motion. There is also a mention of potential confusion about the representation of variables in the equations.
abpandanguyen
Consider 4 frictionless slides described by the equations
(1) y = sqrt(x), (2) y = x, (3) y = 2x, (4) y = x2. If you start at rest at y = h and slide down to y = 0, which statement regarding your speed v at y = 0 is correct?
(1/2)mv2 = KE
mgh = PE
The answer to this question is that all the speeds are equal at y = 0
I know the question asks for speed and that speed is distance over time, so doesn't that mean their speeds should differ taking 1, 2, 3, and 4 into account?
Speed is "distance over time" only if there no acceleration, i.e. when the object covers equal distances in equal times. I don't know what y = x2 means, but if it describes a slide, there must be acceleration in case (4) also. Try conservaion of mechanical energy and see what that tells you.
o whoops I meant to put that as x^2
I solved for v using conservation of mechanical energy but all my v values came out rather different still. I think I might be doing it wrong...
Can you show what you did and exactly how your v values came out wrong?
here's one example
1.
mgsqrt(x) = (1/2)mv2
sqrt(2g(sqrt(x))) = v
2.
mgx = (1/2)mv2
sqrt(2gx) = v
In all cases the initial kinetic energy is zero and the final potential energy is zero. So the initial potential energy is equal to the final kinetic energy. That's conservation of mechanical energy. Now answer this question, if in all cases the mass starts at height h, what is its initial potential energy?
I think I am getting confused by the
y=sqrt(x), y = x etc.
so having that aside, if they all start from the same height, that means they should all have the same initial potential energy and thus same final kinetic energy and given this, when you write the equations out, they all have the same velocity?
is x representing the horizontal distance here?
Yes, they have the same speed.
Yes, it does.
thank you!
want to help me on my other recent post? >_<
  • · Replies 38 ·
