Equation involving inverse trigonometric function
17 replies · 3K views · last reply
phymath7
Solve the following equation:
$$\sin^{-1}(k)=\frac {k^2}{2} +1$$ where 0<k<1.
Maclaurin series expansion for ##sin^{-1}(k)##
I came across the mentioned equation aftet doing a integral for an area related problem.Doing the maclaurin series expansion for the inverse sine function,I considered the first two terms(as the latter terms involved higher power of the argument divided by factorial of higher numbers),doing so the equation then became like the following:
$$k+\frac {k^3}{6}=\frac{k^2}{2} +1$$
But this equation gives one real solution and two complex solution.And the real solution is greater than 1 which doesn't satisfies the condition.So what's wrong?Do I need to consider more terms in the series?But doing so makes the equation much more hardr to solve which I guess the author hasn't intended in the problem.
For x close to 1 your lefthand side does not exceed the 1.5 from the righthand side. But arcsin does (##\pi/2##), so your approach doesn't work...
What is x?The equation doesn't contain x.Moreover,k can't exceed 1,so your assumption(taking k as (##\pi/2##))is wrong.Perhaps you didn't notice it's an inverse trig function.
phymath7 said:
Homework Statement: Solve the following equation:
Relevant Equations: Maclaurin series expansion for ##sin^{-1}(k)##
I came across the mentioned equation aftet doing a integral for an area related problem. Doing the maclaurin series expansion for the inverse sine function,I considered the first two terms(as the latter terms involved higher power of the argument divided by factorial of higher numbers),doing so the equation then became like the following:
The left side is not the Maclaurin series expansion for the inverse sine function. It's the first couple of nonzero terms for the expansion of the sine function.
Or maybe your setup for the area calculation was incorrect. The equation you're asked to solve doesn't seem to have a solution other than by numerical means, so I would suggest going back to the original problem to see if you've made a mistake there.
sin(1.5)=.997
I would take the sine of both sides and do a taylor series around 1.
The left side is the maclaurin series for inverse sine function.Have a look in here:https://mathworld.wolfram.com/MaclaurinSeries.html.
There's no error in the setup(checked from the solution manual)
Frabjous said:
sin(1.5)=.997
Where does this assumption come from?How does that help?
Taking sine of both sides leave us with:
$$k=sin( \frac {k^2}{2} +1)$$.How do we proceed?
Sorry, old habit to use ##x## as independent variable on horizontal axis. Your ##k##, to be sure.
And I did not say ##k = \pi/2## but the value of the ##\arcsin## function near ##k=1##.A simple plot clarifies things. Of course, you had made it already ?
Plot of asin(x), x^2/2 + 1 and x + x^3/6 for x from 0 to 1; asin(x) rises steeply near x = 1 and the two curves cross inside a red circle near the top right.
Clearly the solution is within the red circle. So ##k## should be close to 1, and any series expansion should be around 1, not around zero.
I then plugged in the bounds, 0 and 1. Since k=1 is close to the solution, it is preferable to take series expansion there because it will require less terms for the given number of significant digits required.
Frabjous said:
I then plugged in the bounds, 0 and 1. Since k=1 is close to the solution, it is preferable to take series expansion there because it will require less terms for a given number of significant digits required.
It' clear from graphing utility that k is close to 1,but how do we use that guess?Mainly,I am asking how my Maclaurin series expansion is wrong?Do I need to take more terms?If I do ,then things get more complicated(due to terms with higher power).How to overcome this?
Why are you wedded to the Maclaurin series? It is preferrable to do series expansions as close as possible to the solution so that you can minimize the number of terms that you need.
Do I take a=1 in the Taylor series to do the series expansion?That's what you mean?
Yes. I take it you can accept a numerical solution ?
Yes. You are expanding in powers of k-a. For a=0 (maclaurin) you are doing powers near 1. For a=1 you are doing powers near 0 which has much better convergence.
There's a small problem: ##f'(1)## doesn't exist for ##f=\arcsin##.
A numerical solution, then ?
Graph of asin(x), x^2/2 + 1 and x+x^3/6 for x from 0.994 to 1, y from 1.4 to 1.58; the curves cross near x = 0.997, circled in red.
Which is why I said to take the sine of both sides of the equation in post #5.
Works like a dream !
Graph of y = sin(x^2/2+1) (blue) and y = x (red) on x from 0.994 to 1, y from 0.994 to 1.001, crossing near x = 0.997 inside a red circle.
