Equation of tangent - Implicit or Partial DifferentiatioN?
9 replies · 3K views · last reply
dan38
Need to find the tangent to the curve at: e^(xy) + x^2*y - (y-x)^2 + 3
I just implicitly differentiate the expression to find the gradient and then use the points given to find the equation, right?
Or does this involve partial differentiation?
None of those :wink:
Just differentiate with respect to x, using the chain rule and product rule.
Is it a curve e^(xy) + x^2*y - (y-x)^2 + 3=constant, or a surface F(x,y)=e^(xy) + x^2*y - (y-x)^2 + 3? And at which point do you need to find the tangent or gradient?
ehild
curve at (0,2)
how do you differentiate with respects to "x" if there's a "y" without one of those methods..
dan38 said:
curve at (0,2)
As I said, use product and chain rules. For example, the derivative of the first term would be,
[tex]\frac{de^{xy}}{dx} = e^{xy} (y + x\cdot \frac{dy}{dx})[/tex]
ah I see
would it have been wrong to implicit differentiation then?
dan38 said:
ah I see
Implicit differentiation is used when you cannot differentiate the terms using these methods, specifically when you have to integrate function raised to another function of the same variable. This is not the case with the given curve, so there is no need for implicit differentiation.
Infinitum, what you did, it is implicit differentiation.
y is given as a function of x implicitly by an equation R(x, y) = 0. We differentiate R(x, y) with respect to x and then with respect to y, multiplying it with dy/dx.
ehild
What, exactly, do you mean by "implicit differentiation"? It is clearly called for in this problem.
ehild
You're right. I don't know, but absent-mindedly, I interchange definitions sometimes...
Apologies, dan38!
