Equation relating a function and its inverse
  • Thread starter Thread starter pmqable
    Function Inverse
The discussion revolves around the equation f(x) + f^-1(x) = x^2 and whether it can be solved for the function f(x). Participants clarify that the inverse function f^-1(x) is defined such that f(f^-1(x)) = x, and explore the implications of differentiating the equation. It is concluded that a continuous, invertible function f cannot satisfy the equation across the entire real line due to the properties of monotonicity and symmetry about the line y=x. The conversation suggests that no continuous solutions exist, and any attempts to find examples of f and f^-1 where their sum equals a polynomial function lead to contradictions. Ultimately, the challenge remains unresolved, highlighting the complexities of the relationship between a function and its inverse.
pmqable
so here's the question: if you have some equation relating a function, f(x), and its inverse, f-1(x), can you solve for the function?
for example, solve for f(x):
f(x)+f-1(x)=x^2
how about:
f(x)+f-1(x)=g(x)
my math teacher (AP calc) was stumped on this one... any thoughts?
Mathematics news on Phys.org
By inverse, do you mean
f -1(x) = 1 / f(x)
or that
if f(x) = y, then f -1(y) = x?
by inverse i mean f(f-1(x))=x... e.g. ln(e^x)=x
What if you differentiated the equation? Can you relate the derivative of the function and its inverse? (hint)
I suppose you could differentiate both sides. Then you would get:
f'(x)+f-1'(x)=2x
f'(x)+1/(f'(f-1(x)))=2x
but this equation still does not get rid of the f-1(x)... do you see something I don't?
f'(x)+f-1'(x)=2x
The way the equation is written on the wikipedia page somewhat obscures the point:
$$\frac{df^{-1}(x)}{dx} = \frac{1}{\frac{df(x)}{dx}}$$
(where the inverse exists)
your question is a little strange, since f + f^-1 is only defined where both f and f^-1 are defined. but the domain of f^-1 equals the range of f, so they may not have any common domain at all.
but let's say they do have a common domain interval, e.g. the whole real line.
if you want a continuous solution there cannot be any.
i.e. a continuous invertible function on the line is monotone, say increasing. but then also its inverse is increasing, hence also their sum,
but x^2 is not increasing. so there do not exist any continuous, much less differentiable, f and f^-1 defined on all of R satisfying your equation.
now let's take a finite interval, say [0,1]. then either f(0) = 0 and f(1) = 1 and f is increasing or else f(0) = 1 and f(1) = 0 and f is decreasing. let's assume increasing.
then both f and f^-1 are non negative, and their sum equals x^2, hence both have values everywhere less than or equal to x^2.
this is also impossible, since the graphs of f and f^-1 are symmetrical about the line y=x.
Thus if f has values less than x^2, then f^-1 has values larger than x^2, contradiction.
now let's take a half infinite interval like [a,infinity). then f(a) = a and also f^-1(a) = a, so their sum is 2a, not a^2, unless a=0 or 2. if a=0 i think we already did it above, if a = 2, then f^-1(2) = 2, and both f and f^-1 are increasing so again the graphs are both above the line y=x a contradiction.you might try to think of any examples at all of f and f^-1 where their sum is a polynomial function of x.or maybe you could look at examples of functions f and f^-1 with different domains, but where f+f^-1 = x^2, on some interval common to their domains. that would be harder to study.
  • · Replies 17 ·
