Equation used to find kinetic energy of proton
The discussion centers on determining the kinetic energy of a proton given its wavelength, specifically 100 femtometers (fm). Two methods are proposed: Method 1 utilizes the equation λ = h/p, leading to p = sqrt(2Em), while Method 2 employs the relativistic energy-momentum relationship E² = (pc)² + (mc²)². The consensus is that Method 2 is more accurate due to its incorporation of relativistic effects, especially for high-energy particles. The results from Method 1 and Method 2 can differ significantly, highlighting the importance of using the correct approach based on the particle's energy.
  • Understanding of quantum mechanics, specifically wave-particle duality.
  • Familiarity with the Planck constant (h) and its application in quantum equations.
  • Knowledge of relativistic physics, particularly the energy-momentum relationship.
  • Basic proficiency in classical mechanics, including kinetic energy and momentum equations.
  • Study the derivation and application of the relativistic energy-momentum equation E² = (pc)² + (mc²)².
  • Learn about the implications of wave-particle duality in quantum mechanics.
  • Explore the differences between relativistic and non-relativistic kinetic energy calculations.
  • Investigate the significance of units in physics calculations, particularly in energy and momentum.
Students and professionals in physics, particularly those focusing on quantum mechanics and particle physics, as well as educators teaching the principles of kinetic energy and relativistic effects.
darksyesider
I am having trouble deciding when to use which equation.
If you're given the wavelength of a proton, let's say 100 fm, and have to find the kinetic energy of it, how would you do this?
Here are my ideas:
Idea 1: Use lambda = h/p, where p = sqrt(2Em).
Idea 2: Use E=(pc)^2+(mc^2)^2 = (mc^2)^2+(h/lambda * c)^2
Then I'll use:
K = E- E_o
==> (answer from idea 1 or 2) - mc^2 Which should I use? I personally think idea 2 is correct because it accounts for the relativisitic effects.
thank you!
In your idea 1 you've already given the wavelength to momentum relationship---and you're given the wavelength. That's all you need.
Edit: looks like I misread the question...
but is the equation correct?
I actually forgot how I got p = sqrt(2Em)...I think I derived it earlier in my work.
Also I asked my friend who is learning this in school and he said that you have to use idea 2 because it is a particle?
The relativistic equation is correct in general. Your method 1 is basically non-relativistic, so it's "correct enough" only for low-energy (low-velocity) particles. But it's hard to tell in advance whether the velocity is "low enough" unless you have a lot of experience in doing these kinds of problems. So I would go with your method 2. If you have time, try method 1 also and see how close together the results are.
Hint: start with the non-relativistic formulas for momentum and kinetic energy, p = mv and E = (1/2)mv2.
Thank you everyone! My answer using method 2 was actually 1000 times larger than the answer using method 1. I guess you have to take into account relativity!
I suggest that you check your calculations and particularly your units carefully. My results for the two methods differ by only about 0.004%.
As a check, calculate the proton's speed assuming the classical formula. What % is it of the speed of light?
  • · Replies 54 ·
11K
  • · Replies 18 ·
