Equation used to find the efficiency of a kettle
  • Thread starter Thread starter physicsnerd26
    Efficiency
The efficiency of a kettle can be calculated using the formula: Efficiency = (mass (volume of water) x heat capacity x change in temperature) / (voltage x current x time taken). This equation establishes a clear relationship between energy output and energy input, where energy output is derived from the product of mass, heat capacity, and temperature change, while energy input is determined by the product of voltage, current, and time. Understanding the heat capacity of water, measured in Joules per degree Celsius per kilogram, is crucial for accurate calculations.
  • Understanding of thermodynamics principles
  • Familiarity with electrical concepts such as voltage and current
  • Knowledge of heat capacity and its units
  • Basic algebra for manipulating equations
  • Research the concept of thermal efficiency in heating appliances
  • Learn about the specific heat capacity of various substances
  • Explore the relationship between electrical energy and thermal energy
  • Study the principles of energy conservation in thermodynamic systems
Students studying physics or engineering, appliance manufacturers, and anyone interested in optimizing energy efficiency in heating systems.
physicsnerd26
So, I'm doing this coursework right now, and I know that this equation is what's needed to get to the efficiency but I have only a little idea why.
I'm given this formula:
https://s.yimg.com/hd/answers/i/669504ce234c41af99c351e0c28eea10_A.png?a=answers&mr=0&x=1424239496&s=8a1c1557912955a6446f8f8e90ff7a57
It's Efficiency = (mass (volume of water) x water capacity x change in temperature)/ (voltage x current x time taken)
Is there any theory connected to this? Or other equations that led to this equation?
Perhaps you should look up the definition of 'efficiency'.
Also, don't post duplicate threads in different forums. That's a violation of the rules of PF.
Already have, but am I right to assume that:
mass x water capacity x change in temperature = energy output
and the voltage x current x time taken = energy input?
That's correct.
I think C has to be the heat capacity of water, not the "water capacity" whatever that may be.
The heat capacity of water will be in units of energy per change in temperature per unit mass. For example, Joules per degree C per kilogram.
34K
  • · Replies 17 ·
