Equilibrium of reactions - which direction is favored?
The discussion clarifies the relationship between equilibrium constants and reaction favorability. When the equilibrium constant (Keq) is greater than 1, it indicates that the products are favored and the forward reaction is favored. Even if the reverse reaction proceeds more quickly due to excess products, the equilibrium constant remains a definitive indicator of the favored direction. The key takeaway is that Keq reflects the overall tendency of the reaction, not the instantaneous rates of the forward and reverse reactions.
  • Understanding of chemical equilibrium concepts
  • Familiarity with equilibrium constants (Keq)
  • Knowledge of reaction rates and rate constants
  • Basic grasp of Le Chatelier's principle
  • Study the implications of Le Chatelier's principle on equilibrium systems
  • Learn about the calculation and significance of equilibrium constants (Keq)
  • Explore the relationship between reaction rates and equilibrium positions
  • Investigate the impact of concentration changes on equilibrium states
Chemistry students, educators, and professionals involved in chemical kinetics and equilibrium analysis will benefit from this discussion.
dranseth
Is it the same to say the products are favour and the forward reaction is favoured. Or can the reverse reaction be favoured but the products be favoured. For example, the equilibrium constant is >1 so by definition the products are favoured, but if a system has excess products and the reverse reaction is favoured, then? I am confused.
That was one of the more confusingly phrased questions I've read.
As to your initial question, it is the same to say the products are favored or to say the forward reaction is favored. If the Equi constant is > 1, then the system doesn't have excess products (excess meaning enough to stop the reaction).
Perhaps the semantics of excess is what's confusing you?
Depending on the reaction you can have a hell-of-a-lot of products and still be favoring a forward reaction.
Hope that helps.
I don't understand what you mean by "excess meaning enough to stop the reaction". I'll try to give you a better example of what I am asking.
Say you are given a question and you are told that the equilibrium constant is 4. You are then told to find out if the reaction is in equilibrium, so you calculate it only to find that the equilibrium constant you calculated was 9, so you're obviously not in equilibrium and you have excess products (meaning more products than is needed to be in equilibrium). Wouldn't the reverse reaction be favoured in this case because more reactants have to be made to reach the equilibrium constant 4?
If your "product" is in excess, giving you the higher than expected Keq value, then the reverse reaction will proceed more quickly, to respond to the stress on the equilibrium system.
Thanks, so even if the reverse reaction is proceeding more quickly, the forward can be favoured as depicted by the Keq value > 1?
No. If the forward reaction is favored, then the forward reaction is going faster, and the products are favored - meaning more products are going to be produced.
That doesn't make sense with the definition then. Because in my textbook it defines that if the equilibrium constant is greater than one, then the forward reaction is favoured. Couldn't your reverse reaction be proceeding faster while having a equilibrium constant greater than one?
No, you cant. The equi constant tells you which direction the reaction is going ( / is going faster. Which direction the reaction is going, tells you if the products or the reactants are favored (i.e. forward = reactants favored).
Note that the equilibrium deals with the rate constants and not the actual rates - this aspect is very important.
