Equivalent conditions on a metric space
The discussion centers on proving the equivalence of three conditions regarding a subset A of a metric space X: (i) A is dense in X, (ii) the only closed set containing A is X, and (iii) the only open set disjoint from A is the empty set. The participants confirm that if A is dense, then any closed set containing A must equal X, and they explore the definitions of limit points and open sets to establish the implications between the conditions. The conversation emphasizes the necessity of understanding these definitions to complete the proof effectively.
  • Understanding of metric spaces and their properties
  • Familiarity with the concepts of dense sets and closure
  • Knowledge of limit points and their role in topology
  • Comprehension of open and closed sets in a metric space
  • Study the definitions of limit points and closure in metric spaces
  • Learn about the properties of open and closed sets in topology
  • Explore the concept of interior points and their significance in open sets
  • Investigate the implications of density in various types of metric spaces
Mathematicians, students of topology, and anyone interested in understanding the properties of metric spaces and the relationships between dense sets, open sets, and closed sets.
Adorno
Let X be a metric space and A a subset of X. Prove that the following are equivalent:
i. A is dense in X
ii. The only closed set containing A is X
iii. The only open set disjoint from A is the empty set
N/A
I can prove that i implies ii: assume that there is a closed set B containing A other than X, and show that B must equal X since the closure of A is X.
Presumably I can prove the other implications (ii -> iii and iii -> i) in a similar way but I'm not sure how to get started. Is there a certain property or fact I should be using?
So I take it that your definition of dense is "the closure is the entire space"?
OK, but what is the definition of closure?
Yes, that's the definition of dense I'm using.
The definition of closure of A, as far as I know, is the union of A with its limit points.
Good, now what is a limit point??
I want you to unwind each definition until we see something we can use. Something with open sets and with disjointness...
Ok, so a limit point of A is a point x in X such that every open ball centred at x contains another point of A, right?
I'm not sure where this is going. :-p
OK, so a set A is dense iff all points not in A are limit points, right??
Now, take a ball disjoint from A. Are the points in this ball limit points??
Right.
So if you take an open ball disjoint from A, all the points in the ball are limit points... right?
Adorno said:
Right.
Yes. So can the ball be disjoint from A?? The center of the ball is a limit point, so by definition...
So it contains points of A, and therefore can't be disjoint from A. I see.
But shouldn't I be proving that ii -> iii and iii -> i?
Right. But it's maybe easier to prove ii -> i first. This is extremely easy.
Now, iii -> i shouldn't be too hard if you unwind all the definitions.
Ok, I'll see how it goes.
My/your/our reasoning proves i -> iii doesn't it? The only problem is the question talks about "open sets", but we were talking about (open) balls. Or does the fact that there are no balls mean that there are no open sets? I'm a bit confused about that
Aha, yes. I forgot to mention that. You're paying attention! :-p
Indeed, we only proved now that there are no open balls disjoint from A. But we wish to prove it for open sets.
Therefore, we will need to unwind some definitions again. What is an open set?
Eventually, I want to show that each nonempty open set contains an open ball.
Ok, well my definition of an open set is a set in which every point is an interior point.
I think I see now. If there is a nonempty open set, it contains an interior point, and thus there is an open ball within the set, by definition of interior point. So if there are no open balls there can be no open sets. Right?
Right! That is perfect!
Cool, thanks for your help! I think I've worked out the other parts now.
