Equivalent definitons for primitive polynomials
  • Context: Undergrad
  • Thread starter Thread starter elias001
    Abstract algebra
24 replies · 3K views
elias001
##\textbf{Definition 1:}## Let ##R## be an UFD. A nonzero polynomial in ##R[x]## is said to be ##\textbf{primitive}## if the only constants that divides it are the units in ##R##.
##\textbf{Definition 2:}## Let ##R## be an UFD. Hence highest common factors of finite subsets of ##R## exists, by collecting common factors of the unique factorization of the elements into products of irreducibles.A polynomial ##f(x)\in R[x]## is called ##\textbf{primitive}## if the highest common factors of the non-zero coefficients of ##f(x)## is equal to ##1##. This implies that if ##u\in R## and ##u|f(x)## then ##u## is a unit in ##R.##
##\textbf{Exercise:}## Prove that a polynomial is ##\textbf{primitive}## if and only if ##1_R## is a greatest common divisor of its coefficients. This property is often taken as the definition of primitive.
##\textit{Hint:}## Since ##c_1c_2\cdots c_mf(x)=g(x),## each ##c_i## divides ##g(x).## Therefore, ##c_i## is a unit in ##R##, because ##g(x)## is primitive.
For ##\textbf{Exercise}##, it says the statement in the Exercise can be taken to be the definition of primitive polynomial instead of ##\textbf{Definition 1}##. But according to ##\textbf{Definition 2}##, it seems that the statement of ##\textbf{Exercise}## implies ##\textbf{Definition 1}##. Regardless if it is an implication or an equivalent statements. How does one go about proving either?
Another thing is, how does gcd related to units in a commutative ring, ED, PID or UFD?
Thank you in advance.
I am confused too, and my book actually defines the statement of the exercise as the definition of a primitive polynomial.
I have difficulty seeing where this statement is any different from definition 2 since the zero coefficients do not change anything.
So do you want to prove the equivalence of the two definitions?
@fresh_42 yes, how would one go about proving the equivalence of the two statements. Also i replied to two of my past thread tagging you that you respond to recently.
@fresh_42 the posts are here and here. For the second one, I want to know how to correctly generalized the example in my original post and also, how to count the equivalence classes. I asked grad students and they told me they don't know enough about that specific topic. 😞.
You make me dizzy with all these cross references. I'm old. Let us deal with one thread at a time and simple reply in those threads. I will get an automatic notice. No tags necessary.
First list what we have:
We have a polynomial ##f(x)=a_0x^n+a_1x^{n-1}+\ldots+a_{n-1}x+a_n.## For simplicity, say ##S=\{a_0,a_1,\ldots,a_n\}## and be ##R^0## the units of ##R.##
primitive (def 1) says: ##f(x)## is primitive iff ##\left[\;g(x) \,|\,f(x) \Longrightarrow g(x)\in R^0\;\right]##
Note that ##g(x)\in R^0## means two different things: first, that ##g(x)\in R## and second, that it can be inverted.
primitive (def 2) says: The greatest common divisor of elements in ##S## is ##1.##
Note that it should better be said that ##\operatorname{gcd}S\in R^0## since we can always have other units as divisors. But we don't care about units, so the author says ##\operatorname{gcd}S=1## because it is easier not to deal with obsolete elements like units.
I leave it to you to prove:
a) ##f(x) ## is primitive (def 1) ##\Longrightarrow## ##f(x) ## is primitive (def 2)
and
b) ##f(x) ## is primitive (def 2) ##\Longrightarrow## ##f(x) ## is primitive (def 1).
@fresh_42 i don't get how the gcd of the coefficients of a polynomial in a polynomial ring relates to units in the said polynomial ring. Also for the case of units, it doesn't mean gcd has to be ##1##?
The units in ##R[x]## and the units in ##R## are identical. There are no invertible polynomials except constant polynomials, which are already invertible in ##R.## Adding the indeterminate ##x## doesn't change this unless you do not also add ##1/x## to your ring.
Forget that unit thing. Just pretend ##1## is the only unit. If we had the polynomial ring ##\mathbb{Q}[x]## over the rational numbers, then any non-zero rational number would be a unit. Strictly speaking, ##\dfrac{1}{7}x## would be primitive according to definition 1 but not according to definition 2. That doesn't make sense. It also doesn't make sense to bother about the unit ##\dfrac{1}{7}## since this makes no significant difference. So definition 2 is only a bit sloppy here if it only allows ##1## as divisor and not ##\dfrac{1}{7}.##
Try to concentrate on the logic and not on units.
@fresh_42 let's do ##(a)## first.
We assume that ##f(x)## satisfies def 1 for being a primitive polynomial. Let ##d## be the gcd of the coefficients of ##f(x)##, meaning ##d=\text{gcd}(a_n,a_{n-1},\ldots,a_0).## Let ##S=\{a_n,a_{n-1},\ldots,a_0\},## and each ##a_i\in S## is being divided by ##d##, then ##a_i=dc_i## for some element ##c_i\in R##. Then ##c_i|a_i,## for ##i=0,1,2,\ldots,n.## So ##c_i|f(x)##, and ##f(x)=c_ig(x)## for some ##g(x)\in R[x]##. We have ##dc_i-c_i=0## implying ##c_i(d-1)=0## which gives ##d=1##.
I am not sure how to justify that ##c_i## are units in ##R##?
We assume that ##f(x)## satisfies def 1 for being a primitive polynomial. Let ##d## be the gcd of the coefficients of ##f(x)##, meaning ##d=\text{gcd}(a_n,a_{n-1},\ldots,a_0).## Let ##S=\{a_n,a_{n-1},\ldots,a_0\},## and each ##a_i\in S## is being divided by ##d##, then ##a_i=dc_i## for some unit ##c_i\in R##. Since ##c_i|f(x)##, then ##f(x)=c_ig(x)## for some ##g(x)\in R[x]##. We have ##dc_i-c_i=0## implying ##c_i(d-1)=0## which gives ##d=1##.
Me neither. And you do not need it.
We must show definition 2. So we assume that ##\operatorname{gcd}S=d.## But ##d## divides also ##f(x)## and by definition 1, this means that ##d## is a unit in ##R.## But if ##\operatorname{gcd}S=d## then we also have ##\operatorname{gcd}S=d\cdot d^{-1}=1## since units don't change divisibility properties. And that is what definition 2 requires.
@fresh_42 I just edited my post, does it fix the problem. I am not sure I can just do what you suggest: that since ##d## is a gcd, then it is an unit. I try to just show that ##d=1## according to definition 2. I mean that is the requirement for ##f## to be a primitive polynomial? Also Def 1 states: "...if the only constants that divides it are the units in...". So I think it is require that I need to show that ##d## is an unit, since there are might be other elements that divides ##f(x)## that are not units. In def 1, it doesn't state that gcd are units. Am I reading too much into the definition or do I need to find some way to avoid that issue all together.
elias001 said:
@fresh_42 I just edited my post, does it fix the problem. I am not sure I can just do what you suggest, that since ##d## is a gcd, then it is an unit.
No. It is only a common factor of all coefficients. You can use this factor as ##g(x)=d## in definition 1. It then follows that ##d## is a unit since ##f## is primitive (def 1). You don't need the ##c_i## and the equation ##dc_i-c_i=0## doesn't hold.
elias001 said:
I try to just show that ##d=1##according to definition 2. I mean that is the requirement for ##f## to be a primitive polynomial?
Yes, but this is nitpicking. If ##d## is a unit in ##R,## which it is by definition 1, then there is an element ##d^{-1}\in R.## Now ##d\cdot d^{-1}## also divides all coefficients, so ##\operatorname{gcd}S=d\cdot d^{-1}=1.##
Making that divisor ##1## is just a technical trick.
The other direction is the difficult one.
Say ##f## is primitive (def 2). Then we assume that ##g(x)\,|\,f(x).## Hence, there is a polynomial ##h(x)\in R[x]## such that ##f(x)=g(x)\cdot h(x).##
Now, you must show that ##g(x)## is a unit in ##R,## i.e., that it is a constant polynomial, and the constant is invertible. How? We only know that the coefficients of ##f## have no common divisor, or the divisor ##1## to be exact. How can we use this to get information about ##g(x)##?
@fresh_42 I still don't understand how the portion of Def 1 where it states: "...if the only constants that divides it are the units in..." allows me to infer ##d## is an unit? There are might be other elements that divides ##f(x)## that are not units. I want to get this subtle point sorted out before doing (b).
elias001 said:
@fresh_42 I still don't understand how the portion of Def 1 where it states: "...if the only units that divides it are the units in..." allows me to infer ##d## is an unit? There are might be other elements that divides ##f(x)## that are not units.
Are you sure that is exactly so in the book?
elias001 said:
##\textbf{Definition 1:}## Let ##R## be an UFD. A nonzero polynomial in ##R[x]## is said to be ##\textbf{primitive}## if the only units that divides it are the units in ##R##.
I think it should be ...
elias001 said:
##\textbf{Definition 1:}## Let ##R## be an UFD. A nonzero polynomial in ##R[x]## is said to be ##\textbf{primitive}## if the only factors that divides it are the units in ##R##.
... since I do not see that units in ##R## differ from the units in ##R[x]## which would make it an empty statement.
@fresh_42 I attached a screenshot. Sorry, I made a typo it should say:"...if the only constants that divides it are the units in...". I edited post 1 in Def 1 also to reflect it. Still it doesn't change the fact that I still need to show that ##d## is an unit.
##d## is a unit because definition 1 says so. We have ##d\,|\,f(x)## and definition 1 says that only units divide ##f.##
@fresh_42 I should read that portion of Def 1 as: if ##x|f(x)## and ##x## is a constant, then ##x## is an unit?
I find the notion of primitive polynomial to be not very intuitive and i am having a hard time relating units of a polynomial to the gcd of its coefficients.
I asked one of the LLMs for an explanation, and here is what it says:
Content of a Polynomial: The GCD of the coefficients of a polynomial ##f(x)∈F[x]## is called the content of the polynomial, denoted ##\text{cont}(f).## If ##\text{cont}(f)=d ##, then ##f(x) = d \cdot g(x) ,## where ##g(x)\in F[x]## is a polynomial whose coefficients have GCD ##1## (i.e., ##g(x)## is primitive).
Relation to Units: The content ##\text{cont}(f)## is only defined up to a unit in ##F##. If ##d## is the GCD of the coefficients, then any other element ##d' = u \cdot d## , where ##u∈F^*## (the group of units in ##F##), is also a valid GCD. This is because, in an UFD, if ##d## divides each coefficient, so does ##u \cdot d ##, and vice versa, since ##u## is invertible.
For example:
In ##\mathbb{Z}[x]## , the units are ##\pm 1##, so the GCD of the coefficients is unique up to sign (e.g., ##\text{gcd}⁡(2,4)=2## or ##−2##).
In a field like ##\mathbb{Q}## , all non-zero elements are units, so the content of a polynomial is less significant, as any non-zero constant can be factored out and absorbed into a unit.
Implications for Factorization: The relationship is crucial in Gauss's lemma, which states that for a UFD ##F ##, the content of a product of polynomials satisfies ##\text{cont}(f \cdot g) = \text{cont}(f) \cdot \text{cont}(g)## (up to units). This implies that if a polynomial has content that is a unit in ##F##, it is primitive, and primitivity is preserved under multiplication in ##F[x]##.
Let ##f(x) = a_n x^n + \cdots + a_0 \in F[x]## be a polynomial, where ##a_i \in F.## The content of ##f,## denoted ##\text{cont}(f),## is defined as: ##\text{cont}(f) = \gcd(a_n, a_{n-1}, \ldots, a_0),## where the GCD is taken in the UFD ##F.## In an UFD, the GCD exists and is unique up to multiplication by units. An unit in ##F## is an element ##u \in F## such that there exists ##v \in F## with ##uv=1,## where ##1## is the multiplicative identity in ##F.## The set of units in ##F## is denoted ##F^*.##
Saying that ##\text{cont}(f)## is "defined up to a unit in ##F##" means: If ##d \in F## is a GCD of the coefficients ##\{a_n, \ldots, a_0\}## , then any other element ##d' \in F## of the form ##d' = u \cdot d## , where ##u \in F^*##, is also a GCD of the coefficients.
Conversely, if ##d'## is another GCD of the coefficients, then there exists a unit ##u \in F^*## such that ##d' = u \cdot d##.
In mathematical notation, this can be expressed as
##\text{cont}(f) \sim d \quad \text{if and only if} \quad d \text{ divides } a_i \text{ for all } i, \text{ and any other } d' \text{ with this property satisfies } d' = u \cdot d \text{ for some } u \in F^*.##
Equivalently, the content is an element of the quotient monoid ##\frac{F}{F^*}## , where two elements ##d, d' \in F## are equivalent if ##d' = u \cdot d## for some ##u \in F^*## .
Does the explanation appears to be ok/clear to you?
Not really. It says, that if ##f(x)=a_0+a_1x+\ldots+a_nx^n## and ##d\,|\,a_0,a_1,\ldots,a_n## then ##d=1.##
It doesn't say anything about ##x.## The polynomial ##f(x)=x## is primitive, although ##x\,|\,f(x)## and ##x## isn't constant.
Let me quote how my book (van der Waerden) defines it.
The underlying ring ##R## is an integral domain (commutative and without zero divisors) with ##1.## The greatest common divisor ##d## of ##a_0,a_1,\ldots, a_n## is the content of ##f(x)=a_0+a_1x+\ldots+a_nx^n. ## If we take separate ##d## by writing
f(x)=d\cdot g(x)
then ##g(x)## has the content ##1.## Both, ##g(x)## and ##d## are uniquely determined up to unit factors. Polynomials of content ##1## are called primitive or unit-forms with respect to ##R.## van der Waerden uses the term unit-forms, but that is a bit outdated.
Whatever you call it, it is all about the greatest common divisor of the coefficients of ##f(x),## not ##f(x)## itself, for which we have the terms prime and irreducible. This greatest common divisor is a ring element, i.e. ##d\in R.## As such, it can be ##d=1## or ##d\neq 1.## Units are more or less irrelevant since we can always multiply any units without changing what it is all about. Units of ##R[x]## are even less relevant in this context. You are obsessed with units. Forget them. They are just irrelevant factors (in this context) and play the same role as ##1## does.
You'd better not. You are already confused by using more than one book. I would concentrate on a single book and only ask questions about that specific book (whichever it is). LLMs tell you what they "think" you want to hear. They are worse than Wikipedia!
For example:
That's more or less exactly how van der Waerden defined it. Again, forget about units. They are only a pollution in uniqueness statements.
It is simple. How would you factor the integer ##6##? You would probably answer ##6=2\cdot 3.## This shows that ##6## is reducible. It is also not a prime, since the two terms coincide for integers. However, the reason why ##6## isn't prime is a different one. If ##6\,|\,3\cdot 4## then we cannot conclude ##6\,|\,3## or ##6\,|\,4.## That is why ##6## isn't prime.
Now, what if I were to say my answer to that question is ##6=(-2)\cdot (-3)?## This is certainly true, and, what is more important, wouldn't change any of my previous arguments. We would only need to carry the minus sign through the arguments. ##-2## is a prime number! This is because ##-1## is a unit, and it shows that uniqueness is only given up to factors ##\pm 1,## the units in ##\mathbb{Z}.## And if the ring were a field, we would have many more units. That is why ##\mathbb{Q}## doesn't have any prime elements.
@fresh_42 for (b)
Assumed fact: every polynomial ##m(x)=pq(x)## where ##p## is the gcd of the coefficients of ##m(x)## and the polynomial ##q(x)## is primitive.
Let ##f(x)## be a primitive polynomial with ##\text{content}(f)=1.## Why do/can I suppose that ##g(x)|f(x)?##.
If ##g(x)|f(x)## implies ##f(x)=g(x)h(x)## then the ##\text{content}(f)## is the same as the content of ##h(x),## hence ##h(x)## is primitive. By the assumed fact, ##f(x)=g(x)h(x)=\text{content}(f)h(x).##. This implies ##g(x)=\text{content}(f)=1.##
Here: "the ##\text{content}(f)## is the same as the content of ##h(x),## hence ##h(x)## is primitive." I want to use one more fact that ##\text{content}(f)=\text{content}(gh)=\text{content}(g)\text{content}(h),## then ##1=\text{content}(g)\text{content}(h)## implying ##\text{content}(g)## is an unit, so ##g(x)## is primitive. But then I don't know how to conclude that "the ##\text{content}(f)## is the same as the content of ##h(x),## hence ##h(x)## is primitive.". Maybe I can do the same argument like with ##g(x)##.
By the way, I now know why Def 1 is troubling me. If we are working in ##\Bbb{Q}[x]##, the polynomial ##3x^2+9x+15## has gcd of its coefficients equals ##3##, but that doesn't satisfy Def 2 since it requires gcd to be ##1##.
elias001 said:
@fresh_42 for (b)
We have to. We know that ##f(x)## is primitive (def 2). Now, if we want to show ##f(x)## is primitive (def 1), we have to show what definition 1 states. The statement is, if ##g(x)\,|\,f(x)## then ##g(x)\in R^0.## Hence, we must assume that ##g(x)\,|\,f(x)## since these are the only relevant cases. All others don't matter.
Let me sort this out. We know that ##f(x) ## is primitive (def 2), i.e., the content of ##f(x)## is ##1.## We also know that ##f(x)=g(x)\cdot h(x).## What we need next is that the content of a product is the product of the contents of the factors. This should be proven. Given that we have
1=\operatorname{content}(f(x))=\operatorname{content}(g(x))\cdot \operatorname{content}(h(x)).
But this is an equation in ##R,## so ##\operatorname{content}(g(x))## and ##\operatorname{content}(h(x))## are units by definition of a unit. Hence, ##g(x)## and ##h(x)## are primitive (def 2). The contents are not exactly ##1## but units, which is good enough. If ##g(x)=d\in R## then ##d\in R^0## which proves that ##f(x)## is primitive (def 1).
Me, too. I made a mistake. It is really what you said. It has to be
definition 1: ##f(x)## is primitive iff ## d\,|\,f(x) \wedge d\in R \Longrightarrow d\in R^0.##
Since ##x+x^2## is primitive, and ##x\,|\,(x+x^2)## we cannot conclude ##x\in R^0.## We must demand ##R\ni d\,|\,f(x).##
No. If we are working in ##\mathbb{Q}[x]## then any non-zero number is a unit. There is no greatest common divisor since all numbers are divisors, and up to units it is ##1## which is as good as any other non-zero number.
Your argument is only valid in ##\mathbb{Z}[x],## in which case ##3x^2+9x+15## isn't primitive whether you use definition 1 or 2.
That is why van der Waerden added "... primitive with respect to ##R##" and why I repeat the mantra of saying which ring you refer to.
@fresh_42 for (b) how do I put it all together. I am a little confused over our back and forth as to what can be used and what I need to do more justifications. I am using two facts:
Fact 1. Every polynomial in a polynomial ring can be written as a product of its content and a primitive polynomial.
Fact 2. ##\text{content}(f(x))=\text{content}(g(x))\cdot\text{content}(h(x)).##
So if I have ##f(x)=g(x)h(x)\quad (*)##, and we also have ##f(x)=\text{content}(f)h(x)\quad (**)##, then ##f(x)=g(x)h(x)=\text{content}(f)h(x),## and ##\text{content}(f)=1##, so in ##(**)## I can conclude that ##h(x)## is primitive from Fact 1? Also since ##\text{content}(f)=g(x)=1##, then I can also conclude that ##g(x)## is also primitive?
let's leave the issue of Def 1 with the issues of contestants and units for now until after (b) is resolved, since i think that might affect whether the argument in (a) need to be modified to take into account which ring one is speaking about.
Sorry, my bad. Let's clean up the mess a bit.
_________________________________________
We start with ##R## being a UFD and particularly an integral domain, so no zero divisors except ##0.## The units in ##R## will still be denoted as ##R^0.##
definition 1: ##f(x)\in R[x]## is primitive iff ##\left[d\,|\,f(x)\wedge d\in R\Longrightarrow d\in R^0\right].##
definition 2: ##f(x)=a_0+a_1x+\ldots+a_nx^n\in R[x]## is primitive iff ##\operatorname{gcd}(a_0,\ldots,a_n)=1.##
a) Definition 1 ## \Longrightarrow ## Definition 2:
Let ##d=\operatorname{gcd}(a_0,\ldots,a_n).## Then ##d\in R## and ##d\,|\,f(x).## By definition 1, this implies that ##d\in R^0.## Thus, it is invertible, i.e., ##d\cdot d^{-1}=1## with ##d^{-1}\in R^0.## Finally, if ##d=\operatorname{gcd}(a_0,\ldots,a_n)## then so is ##1=d\cdot d^{-1}=\operatorname{gcd}(a_0,\ldots,a_n)## proving definition 2.
b) Definition 2 ## \Longrightarrow ## Definition 1:
To prove definition 1, we need an element ##d\,|\,f(x)## with ##d\in R.## This means that ##d## is a divisor of all coefficients of ##f(x).## Therefore, ##d## divides the greatest of all common divisors, i.e.,
d\,|\,\operatorname{gcd}(a_0,\ldots,a_n)=1
by definition 2. But if ##d\,|\,1## then it is an element from ##R^0## by definition of units. If ##d\in R^0## then this is exactly what definition 1 requires to be shown.
Fact 1 is simply the distributive law in ##R.## Fact 2 seems obvious, but I suggest you try to prove it formally.
@fresh_42 The way you rewrote (a) accounts for different polynomial rings: ##\Bbb{Q}[x], \Bbb{Z}[x].##
For Fact 1, Hungerford gave a weird direct proof. Screenshots:
Here is a proof by contradiction from a YT video
Can I ask you about the other post about that localization example?
Sure, but do it there or even better in a new thread.
