Equivalent Pressure Washing Tests
The discussion revolves around the challenge of simulating a specific washdown scenario for a design project, specifically aiming to replicate a volumetric flow rate and pressure combination using a household pressure washer. Participants explore the feasibility of using a pressure washer rated at 2500 psi to mimic the conditions of 85 psi and 75 gpm.
  • One participant seeks to determine if a household pressure washer can replicate the conditions of 85 psi and 75 gpm, expressing uncertainty about the feasibility of this approach.
  • Another participant asks for clarification on whether the focus is on verifying pressure drop through a nozzle or pipe, indicating the need for specific details to assist further.
  • A participant elaborates on the goal of mimicking a volumetric flow rate and pressure combination, questioning if a solution at 2500 psi could provide an equivalent experience and how to calculate the necessary pressure and flow rate combination.
  • Another response suggests that if the aim is to replicate the effect of a high-pressure water jet, having the same inlet pressure may suffice for achieving similar velocities, though it may not cover the same area effectively.
  • Concerns are raised about the effectiveness of comparing high flow, low pressure nozzles to low flow, high pressure nozzles, emphasizing that the ability to remove debris depends on the impact velocity of the water, which is influenced by nozzle inlet pressure.
Participants express differing views on the feasibility of using a household pressure washer to replicate the desired conditions. There is no consensus on whether the proposed approach is valid or how to accurately calculate the necessary parameters.
Participants mention the need for specific calculations related to pressure drop and the impact of water jet velocity, indicating that assumptions about nozzle performance and area coverage may affect the discussion.
ddelaiarro
I have a washdown spec for a unit we are designing. We need to be able to withstand a maximum of 85 gpm through a 5/8" nozzle at 75gpm. Now, I don't have access to equipment that can mimic that scenario.
What I'm wondering if can I use my average, run-of-the-mill, garden-variety pressure washer (rated at 2500psi) to mimic that test?
I'm looking at needing about 14gpm through that setup (based on calculations from http://books.google.com/books?id=_7...resnum=3&ved=0CCgQ6AEwAg#v=onepage&q&f=false").
Can someone help me justify that calculation? I'm at a loss here...
Hi ddelaiarro, I'm not clear on what you're looking for. Do you want to verify the pressure drop of water through a nozzle? Or perhaps through a pipe? Or both? If so, what flow and what diameter pipe/nozzle? Please be as specific as possible.
What I'm really trying to do is figure out if there is a way to mimic a volumetric flow rate and pressure combination to another volumetric flow rate and pressure combination.
So, for instance, I can't create the ideal situation of 85psi and 75gpm, but I'm wondering if A) a solution at 2500psi and some VFR would be an equivalent 'experience' to our module and, if so, B) how do I calculate the correct pressure/VFR combination.
Basically, I want to simulate the environment of 85psi/75gpm with the equipment I have at my disposal (a household pressure washer capable of 2500psi) - I don't even know if that's possible. My gut tells me no, but I can't mathematically prove myself right or wrong.
What are you trying to duplicate? The pressure drop through the system or the affect of aiming a high pressure water jet at something to remove material/dirt? If the former, it's easy enough to do the calculations on pressure drop through piping. You can find a manual that explains the basics https://www.physicsforums.com/showthread.php?t=179830". If you're trying to duplicate the affect of a high pressure water jet, then having a water jet with the same pressure going in is sufficient to get the same velocity. It may not be as effective simply because it doesn't cover the same area, but I'd think it should give you a very good idea of how effective a water jet having some given inlet pressure should work at removing material or debris. I don't think reducing the nozzle inlet pressure and comparing a high flow, low pressure nozzle to a low flow, high pressure nozzle is reasonable. The ability to remove debris is going to be a function of the impact velocity of the water which is only a function of nozzle inlet pressure.
15K
