Escape Velocity Calculation for an Object on Earth
9 replies · 5K views
Stratosphere
How do you Calculating the escape velocity? I googled it but they give bad instructions on how to do it. What is the formula?
Every time I try using the formula i have i have to solve for V^2 and I get it to equal 35
3541. Is this right? I plug in the numbers like it says it I still don't get the right answer.
Gravitational potential energy is = GMm/r (where M is the mass of the earth)
Kinetic energy = 1/2 m v^2
You start at r=radius of Earth and end up at r=infinity.
A bit of rearranging and a subtraction and it shoudl be easy
I set KE=GPE i get a velocity of 465,561 for a 10kg object. This doesn't seem right.
Well escape velocity is a function of radius so this question, as you stated, makes no sense...
What formula are you using?
V[tex]^{2}[/tex]=[tex]\frac{2GM}{R}[/tex] to find the escape velocity of the Earth and i get, 465561.808.
Stratosphere said:
[itex]V^{2}=\frac{2GM}{R}[/itex] to find the escape velocity of the Earth and i get, 465561.808.
You've got "tex" tags inside your formula. I've tried to fix tags in the quoted extract; but it is still not displaying for some reason. But the formula looks fine to me. Just make sure all your variables are in consistent units. You give a number, but no units. Are you meaning km/hr, or m/s, or something else?
The gravitational constant G is usually given in SI units. If you do everything in meters and seconds and kilograms, it will work.
Okay, from this answer, I'd say that you are using kilometers instead of meters for the radius of the Earth.
Why would the mass of the object matter ?
GM for the Earth is almost exactly 400,000 km^3/s^2 (worth remembering)
The radius of the Earth is around 6400km
so v^2 = 2GM/r = 2*400,000/6400 = 225km^2/s^2
v = 11.2km/s (roughly)
edit - sorry i posted this straight after you replied, but it didn't show up (got a database error message)
