Esters' high boiling point
3-methylbutyl ethanoate has a higher boiling point than 3-methylbutan-1-ol and ethanoic acid primarily due to its larger molar mass and higher density, which contribute to stronger induced dipole-induced dipole interactions. While alcohols and carboxylic acids exhibit stronger hydrogen bonding, the overall intermolecular forces in the ester can still result in a higher boiling point. The discussion emphasizes that boiling points are influenced by various factors, including molecular weight and the nature of intermolecular forces. Comparisons with other compounds reveal that boiling points vary significantly across different functional groups. Understanding these interactions is crucial for predicting boiling point trends in organic compounds.
Shyanne
You have to show your attempts at answering the question, this is a forum policy. Also, all homework like questions should go to homework forum.
Why does 3-methylbutyl ethanoate have a higher boiling point than 3-methylbutan-1-ol and ethanoic acid?
Attempt at a solution: I know that the ester has a marginally greater molar mass but I wasn't sure if this is the only deciding factor, particularly considering the strength of the other interaction forces between alcohol and carboxylic acid molecules.
I can't give you the exact answer because of the rules but I can tell you this...it has something to do with intermolecular forces of attraction and this link may help you.
I understand that intermolecular forces of attraction are stronger in alcohol and carboxylic acid but it doesn't make sense then that the ester would have a higher boiling point?
The intermolecular forces do not depend entirely on the ability of a molecule to make hydrogen bonds.
So would I be correct in saying that the ester's boiling point is slightly higher due to its larger molar mass?
Yes :)...and remember this 3-methylbutyl ethanoate has a higher density than both ethanoic acid and 3-methylbutyl-1-ol, thus it is easy to say it will have a higher b.p cause of that and beacuse the induced dipole-induced dipole forces are greater.
Hm... let´s compare various simple compounds with 6 heavy atoms.
Hexane, C6H14: n-hexane 69 degrees, isomers less, down to neohexane, 50 degrees.
Pentanols, C5OH12: 1-pentanol 138 degrees, isomers less, down to tertiary pentanol, 102 degrees.
Ethers C5OH12: methyl tert-buthyl ether 55 degrees
Aldehydes C5OH10: n-pentanal 102 degrees
Ketones C5OH10: 2-pentanone 102 degrees, 3-methyl-2-butanone 92 degrees, 3-pentanone 101 degrees
Acids C4O2H8: n-butyric acid 164 degrees, isobutyric acid 155 degrees
Esters C4O2H8: ethyl acetate 77 degrees
28K
