Estimating efficiency of a system
  • Thread starter Thread starter Pinon1977
    Efficiency System
26 replies · 4K views
Pinon1977
TL;DR
Trying to determine if you can estimate the efficiency of a system with a derived known efficiency as the reference starting point.
Please see the attempt sketch. Basically I have four very inefficient DC motors all commonly turning a single drive shaft at the center of the system. Currently these motors that are 2.47% efficient individually able to produce 5 newton meters of torque at 28 RPMs. So my question is this. If I replace those 2.47% efficient motors with a motor that is exactly the same but 90% efficient, can I use a multiplier of 36.4 to roughly estimate what the new torque value would be? (.5 Nm * 36.4 = 18.4 Nm)
Well, almost.
The gearbox has some losses you did not account for - for instance:
If that gear box is only rated for the original torque, the system efficiency will be Zero when the gear teeth break off! :oops:
Cheers,
Tom
That would be awfully low. So low that it's already suspicious.
Could you please tell us how did you determined the efficiency of those DC motors?
Another spin on this very weird question:
Electric motors are rated based on output power and rpm, not input electrical power so if you replace these 4 motors with otherwise identical single motor at much higher efficiency it will provide 1/4 the output power that the 4 motors do combined.
You seem to be approaching this problem backwards, but it is hard to tell because we need the rest of the story we aren't getting...
I'm strictly talking from an individual motor perspective..... let's just forget about the gearbox for the moment. If the existing motor is currently at 2.47% with the capability of producing .5 newton meters at 28 RPMs on a bench test, could we replace that motor with a 90% efficient motor and use a multiplier to presume what the new output to work would be?
Sure, I used a digital torque transducer, an oscilloscope,, MATLAB, and some output data to come up with this efficiency number. Please see the attached screenshots.
I'm strictly talking from an individual motor perspective..... let's just forget about the gearbox for the moment. If the existing motor is currently at 2.47% efficiency with the capability of producing .5 newton meters at 28 RPMs on a bench test, could we replace that motor with a 90% efficient motor and use a multiplier (36.4) to presume what the new output torque would be?
Bench test set up was as follows:
Again, since motors are rated based on output, no, the output torque would not change.
Now, is this really theoretical or are you looking at real motors? What is the real point/purpose of this exercise?
Bordering on trolling, IMO.
@Pinon1977 -- please upload a photo of the motor. Is it made from paperclips and a bar magnet?
I'm trying to be serious here, yet almost everyone of you guys feels that these questions are an open invitation for you guys to start your own open mic night at the comedy club. I'm trying to be serious here and I need serious consideration please.
russ_watters said:
Please see attached spec sheet for the exact motor I'm using. Yes, I am pushing it beyond its normal operating capabilities to get it to do what I needed to do. I get that. I bench test this motor across a broad spectrum of RPMs and loading characteristics. I used a digital torque transducer and matlabs to process the data. I will also attach a screenshot of that information. To answer your question, I never said it was theoretical, I said is it possible to come up with a theoretical based upon a real world known efficiency. And that particular efficiency in my case is 2.47% efficient. Horrible I know, but just go with it.
Reference: https://www.physicsforums.com/threads/estimating-efficiency-of-a-system.1055167/#post-6926192
Pinon1977 said:
And for the record, I never said it was strictly theoretical or strictly real motor data. It's both. I have a known set of established values that I've came up with using highly precise scientific instruments, and I'm wanting to know if I can presume certain facts to get in essence get a theoretical motor that is much more efficient to get the torque I need. That's all I'm trying to do. I'm trying to not have to buy six or seven different motors whenever I can maybe take an educated guess at the one that I need and have it be the right one.
And I don't know what trolling means, but I assure you it does not sound like it's a good thing. I'm doing nothing nefarious here, just trying to get you guys to give me some advice on a presumption.
I label the Matlab data here so you can see what I was getting from the digital torque transducer
Trolling means not being sincere in your posts or images. I'm not able to decode your fuzzy images that you've uploaded. Please post links to your 4% efficient electric motor datasheet.
Here's the full report. Please see attached. The data points that are illustrated on the second page are just the first few seconds of the test. The entire file included thousands of data points over 200 seconds.
Are you able to open up that adobe file?
Did you get my response? I've given you everything that you asked for I believe.
Simple answer: Yes, if the two motors are at the same RPM. Efficiency is comparing power, not torque.
More complex answer: If the new motor is 90% efficient instead of 2.47%, I highly doubt that it "is exactly the same". But if you do find a motor with a rated 90% efficiency at the same current, voltage, and RPM then the new motor torque will necessarily be 36.4 times the torque of your motor.
Your motor is putting out near its rated torque according to its data sheet.
5.6kgf-cm = 0.55n-m
See:
https://www.justintools.com/unit-co...1=kilogram-force-centimeters&k2=newton-meters
Also, your motor seems to be over loaded or defective. 28RPM vs. 113RPM??
Datasheet says 113RPM @ 24V, and 5.6kgf-cm @ 0.2A
Your Test Data 28RPM @ 24V, and 0.4n-m @ 0.4A
Or perhaps your test setup has a problem.
For DC motors especially, no-load Speed is proportional to applied Voltage, Current is proportional to Load (Torque).
Cheers,
Tom
Well, the data sheet indicates much better efficiency than you measured. It may be because of how you are running or measuring it (edit: or motor fault as Tom suggests). Again, as I said, motors are rated for output power. So your best bet is to look at data sheets and find a motor that matches your requirements and buy that. You're approaching the problem backwards and I think applying constraints you don't know/guessed instead of what you do. .
I'm not sure what information you are looking at when tring to select the motor. And where are you getting this 90% efficiency number?
Took some time to piece things together :doh:
Yep. When I noticed you have no noise on your 'measurements' from the linked tables I could smell that there is a trick somewhere...
I won't comment on made-up data, since in this context that's about expectations and not about measuring anything. Next time please make sure you properly mark real and theoretical stuff. For theoretical purposes it's not that bad to make things up but against readers, colleagues and any audience you are expected to properly identify which is which and what is why.
IRL it's a career ruining type of issue. Mind it. Seriously.
Based on the provided information - 'I am pushing it beyond its normal operating capabilities to get it to do what I needed to do.' - you have proper, high efficiency drives operated far out of normal op range.
You need to reevaluate the requirements and get a motor which can do the job while operating within spec.
Unless specified by the manufacturer there is no way to tell what happens out of normal working envelope. And adding more variables won't help that.
If you bring any new '90% efficient' motor out of spec, it'll of course won't operate at the specified efficiency. You'll be back at square one.
  • Love
Rive said:
Took some time to piece things together :doh:Yep. When I noticed you have no noise on your 'measurements' from the linked tables I could smell that there is a trick somewhere...
I am pushing this motor beyond it's normal operating range. I get it. However, this is all they gave me to work with on this preliminary design. It's a proof of concept to justify investing more money to get the proper motors paid for and installed. The proper motors for this configuration will run about a 600 or $700 a piece. I want to make sure that I'm getting the right ones and that's why I brought this whole question up to you guys. Maybe I should have given you guys the whole back story, but I didn't think that those details were important. It was really a simple question, and I got the answer that I thought I would. Loosely speaking, efficiency would have a direct impact on your output torque. And I get it I'm going about this a little backwards. I understand that as well. I already know what I need to order, I just need someone else besides myself to tell me that what I was going to order would produce what I needed
Also, I don't know what you were referring to in terms of trick somewhere. Consequently I don't know which chart you are referring to, but there's all kinds of noise in that chart that I posted..
Thank you Mr Jack action. This question, although it has become quite convoluted in more difficult than necessary, was supposed to be a simple question. So I was correct in loosely presuming that efficiency would mean more torque on the back end. I'm just trying to make this argument to some investors so we can get the motors that I need, not the motors that I had laying around. Thank you for your concise and prompt answer. Have a good day
Pinon1977 said:
....I got the answer that I thought I would. Loosely speaking, efficiency would have a direct impact on your output torque. And I get it I'm going about this a little backwards. I understand that as well. I already know what I need to order, I just need someone else besides myself to tell me that what I was going to order would produce what I needed
Evidently you heard what you wanted to hear and are likely ordering the wrong thing and wasting your investors' money. Or just our time if this isn't real. The approach you took can't possibly yield a useful motor selection. You pulled an efficiency out of thin air and then applied backwards. This is bizarre.
