Estimating the maximum possible percentage error
  • Thread starter Thread starter benji123
    Error Maximum
8 replies · 13K views · last reply
benji123
Hi all! I am new to the forum, came across it from googling the problem which I had and someone was having difficuilty with a question like this on here! Here's the question I have...
The coefficient of rigidity, n, of a wire of length L and uniform diameter d is given by
n=AL/d^4
If A is a constant and the parameters L and d are known to within ± 2% of their correct values, estimate the maximum possible percentage error in the calculated value of n.
n=AL/d^4
dn = dn/dL x dL + dn/dA x dA
dn = A/d^4 dL + L/d^4 dA
n = A/d^4 x ΔL + L/d^4 x ΔA
n = ΔL/L + ΔA/A
Where do I go from here? Any help will be greatly appreciated :)
Welcome, benji. You have come to a good place for help.
n=AL/d^4
n=AL/d^4
A is a constant, so dn/dA doesn't make any sense. Instead, you want dn/dd. For the record, dn/dL and dn/dd are really the partial derivatives of n. I.e.,
[tex]\frac{\partial n}{\partial L} \text{and} \frac{\partial n}{\partial d}[/tex]
n = ΔL/L + ΔA/A
For the percent change in n, you want dn/n.
Thanks for the reply Mark :) and correcting me with the dn/dA and dn/dd situation!
I was wondering, how do I get the estimation when I have no values to work from for L and d?
Mark44 said:
You don't have L and d, but you have their relative errors: ΔL/L and Δd/d.
What do I do with the relative error? As "Δd" will be 2% what will I use for "d" ?
No, Δd is not a percent value; it is the error in determining d. The relative error, which is what you are given, is Δd/d, and that is .02. Actually, what is given is that |Δd|/d <= .02. Same with L and ΔL.
So would it be...
% change in n = % change in L - (4 times % change in d)
% change in n = -2 - (4 times -2)
% change in n = -2 +8
% change in n = + 6%
Therefore, ±2% change in L and d = ±6% change in n?
benji123 said:
So would it be...
No. Where are you getting the -2 numbers?
You started off in the right direction, but didn't fix the errors I pointed out earlier, so let's start from the beginning.
n = AL/d4
[tex]dn = A(\frac{\partial n}{\partial L}~dL + \frac{\partial n}{\partial d}~dd)[/tex]
The percent change in n is Δn/n. Fill in the partial derivatives in the equation above and divide both sides by n.
There is a more elementary way.
[tex] n \propto L[/tex]
means that n increases with increasing L, while
[tex] n \propto d^{-4}[/tex]
means that n decreases with increasing d.
Therefore, the smallest value for n is obtained by taking the smallest value for L and the largest value for d:
[tex] n_{\mathrm{min}} = A \, \frac{L_{\mathrm{min}}}{d^{4}_{\mathrm{max}}}[/tex]
The largest value for n, on the other hand, is obtained by taking the largest value for L and the smallest value for d:
[tex] n_{\mathrm{max}} = A \, \frac{L_{\mathrm{max}}}{d^{4}_{\mathrm{min}}}[/tex]
In this way, you obtain an interval for the possible values of n:
[tex] n \in [n_{\mathrm{min}}, n_{\mathrm{max}}][/tex]
Instead of the interval notation, one usually uses the "techincal notation":
[tex] n = \bar{n} \pm \Delta n[/tex]
which actually means:
[tex] \left\{\begin{array}{l}<br /> n_{\mathrm{min}} = \bar{n} - \Delta n \\<br /> <br /> n_{\mathrm{max}} = \bar{n} + \Delta n<br /> \end{array}\right. \Leftrightarrow \left\{\begin{array}{l}<br /> \bar{n} = \frac{1}{2} \, (n_{\mathrm{min}} + n_{\mathrm{max}}) \\<br /> <br /> \bar{n} = \frac{1}{2} \, (n_{\mathrm{max}} - n_{\mathrm{min}}) \\<br /> \end{array}\right.[/tex]
Then, of course, the relative uncertainty, expressed in percent, is defined as:
[tex] \delta_{n} \equiv \frac{\Delta n}{\bar{n}} \cdot 100\%[/tex]
It is up to you to:
1. Find Lmin and Lmax by knowing [itex]\bar{L}[/itex] (the nominal value) and [itex]\Delta L = \delta_{L}/{100 \%} \, \bar{L}[/itex] (the absolute uncertainty);
2. Do the same for dmin and dmax;
3. Find nmin and nmax according to the above formulas;
4. Find [itex]\bar{n}[/itex] (nominal value) and [itex]\Delta n[/itex] (absolute uncertainty) according to the above formulas;
5. Find the relative uncertainty [itex]\delta_{n}[/itex].
