Finding the Inverse of 2 (mod 17): Euclidean Extended Algorithm
To find the inverse of 2 modulo 17, the Extended Euclidean Algorithm is applied, revealing that the greatest common divisor (gcd) is 1, which allows for the existence of an inverse. The calculations show that 1 can be expressed as a linear combination of 2 and 17, leading to the equation 1 = 17 - 2(8). However, the initial conclusion of the inverse being 8 is corrected by recognizing that the equivalent positive inverse is 9, since -8 mod 17 equals 9. The discussion emphasizes the importance of clearly stating the linear equation being solved, which aids in applying the algorithm correctly. Ultimately, understanding the relationship between negative and positive equivalents in modular arithmetic is crucial for finding the correct inverse.
FritoTaco
Hi, I'm doing a problem by solving congruences but my question is simply trying to find the inverse of 2 \enspace (mod\enspace 17) from 2x \equiv 7(mod \enspace 17).
It's hard to find a definition that makes sense but if you check my upload images you can see exactly what I'm trying to do.
Source:
[/B]
Going forwards
1.) 2 = 17(0) + 2
2.) 17 = 2(8) + 1
3.) 2 = 1(2) + 0
Our gcd = 1 which means we can find the inverse starting with step 2.
Going backwards
4.) 1 = 17 - 2(8)
5.) 2 = 2 - 17(0) we wrote this from step 1 by setting the remainder equal to everything else.
6.) 1 = 17 - (2 - 17(0))(8) plug in the equation from step 5 into 2 from step 4.
7.) 1 = 17 - 2(8)
So our answer says the inverse is 8, but the answer is 9. Where am I messing up?
Your answer says 1 = 17 - 2(8) = 17 + 2(-8).
Does that help?
Likes FritoTaco
Does that help?
Oh, I remember my teacher wrote it like this. So, I'm kinda guessing. But the answer should be between 0 and 17? And just by looking at it 17 - 8 = 9. Is this the reason?
That's the reason. You could also say -8 ≡ 9 mod 17.
Likes FritoTaco
Awesome! Thanks for helping me. There were a few other problems I had the same issue with and couldn't remember what else I was supposed to do, but now it all works.
One other thing that I think would help you would be to first write out the linear equation you are trying to solve. In this case, 2x = 1 mod 17 (I think was what you meant to say in the problem statement) implies that 2x + 17y = 1 for some integers x and y. That makes it clear what you are applying Euclid's algorithm to.
Likes FritoTaco
My teacher never used this method so I don't know if I will actually use it but maybe we will. Thanks!
