Euler-Lagrange equation on Lagrangian in generalized coordinates
The discussion focuses on the derivation of the Euler-Lagrange equation using the Lagrangian expressed in generalized coordinates. Participants clarify the relationship between generalized coordinates and Cartesian coordinates, emphasizing the role of the mass metric tensor in kinetic energy calculations. The conversation highlights the derivation of the equations of motion, particularly the second term's contribution from the kinetic energy's dependence on generalized coordinates. There is also a correction regarding the presence of a missing factor of 1/2 in one of the terms of the Euler-Lagrange equation. Overall, the thread illustrates the complexities involved in transitioning from Lagrangian mechanics in Cartesian coordinates to generalized coordinates.
zhaos
I need some help understanding a derivation in a textbook. It involves the Lagrangian in generalized coordinates.
The text states that generalized coordinates {q_1, ..., q_3N} are related to original Cartesian coordinates q_\alpha = f_\alpha(\mathbf r_1, ..., \mathbf r_N)
Makes sense to me...
Velocities in general coordinates are, by the chain rule,
\dot{\mathbf r_i} = \sum_{\alpha=1}^{3N} \frac{\partial \mathbf r_i}{\partial q_\alpha} \dot{q_\alpha}
Ok so then kinetic energy in cartesian is
K = \frac{1}{2} \sum_{i=1}^N m_i \dot{r_i}^2
So KE in new velocities is then
\tilde{K}(q, \dot{q}) = \frac{1}{2} \sum_{\alpha=1}^{3N} \sum_{\beta=1}^{3N}[\sum_{i=1}^{N} m_i \frac{\partial \mathbf r_i}{\partial q_\alpha}\cdot \frac{\partial \mathbf r_i}{\partial q_\beta}] \dot{q_\alpha} \dot{q_\beta}
= \frac{1}{2} \sum_{\alpha=1}^{3N} \sum_{\beta=1}^{3N} G_{\alpha\beta}(q_1, ..., q_3N) \dot{q_\alpha} \dot{q_\beta}
where the text calls the expression in brackets the mass metric tensor.
Ok, so then given this new KE, the Lagrangian (KE - PE) is
L = \frac{1}{2} \sum_{\alpha=1}^{3N} \sum_{\beta=1}^{3N} G_{\alpha}{\beta}(q_1,...,q_{3N})\dot{q_\alpha} \dot{q_\beta} - U(\mathbf r_1(q_1,...,q_{3N}), ..., \mathbf r_N(q_1, ... , q_{3N}))
All of the above makes sense to me, but then the text substitutes the lagrangian into the Euler-lagrange equation and gets the equation of motion for each q_\gamma, \gamma = 1, ... 3N
\sum_{\beta=1}^{3N} G_{\gamma\beta}(q_1,...,q_{3N})\ddot{q_\beta} + \sum_{\alpha=1}^{3N} \sum_{\beta=1}^{3N} [\frac{\partial G_{\gamma\beta}}{\partial q_\alpha} - \frac{\partial G_{\alpha\beta}}{\partial q_\gamma} ]\dot{q_\alpha}\dot{q_\beta} = -\frac{\partial U}{\partial q_\gamma}
(Euler-lagrange: \frac{d}{dt}(\frac{\partial L}{\partial \dot{q_\gamma}}) - \frac{\partial L}{\partial q_\gamma} = 0)
Ok, so I can see where the first and third term in the equation of motion are coming from. The first is a result of \frac{d}{dt}(\frac{\partial L}{\partial \dot{q_\gamma}}) acting on the kinetic energy part of the Lagrangian. The third term is the result of \frac{\partial L}{\partial q_\gamma} acting on the potential energy part of the Lagrangian. The mass metric tensor is a function of the q's, so I feel like the second term is coming from \frac{\partial L}{\partial q_\gamma} acting on the kinetic energy term, but that's where I'm stuck.
Where does \frac{\partial G_{\gamma\alpha}}{\partial q_\alpha} come from?
It comes from the total derivative with respect to t. \frac{d}{dt}G(q_1,...,q_{3N})=\sum{\frac{\partial G}{\partial q_k}\dot q_k}
ehild
Likes 1 person
That was tricky to see because of the way the terms were grouped.
I worked it through, and now I get it. Thank you.
Ok, so it goes on though. This text develops the Hamiltonian in generalized coordinates:
H(q_1, ... , q_{3N}, p_1, ..., p_{3N}) = \frac{1}{2} \sum_{\alpha=1}^{3N} \sum_{\beta=1}^{3N}p_\alpha G^{-1}_{\alpha\beta}(q_1,...,q_{3N}) p_\beta + U(\mathbf r_1(q1,...,q_{3N}),...,.\mathbf r_N(q1,...,q_{3N}))
And says Hamilton's equations of motion are
\dot{q}_\alpha = \frac{\partial H}{\partial p_\alpha},\ \ \ \dot{p}_\alpha = -\frac{\partial H}{\partial q_\alpha}
And how did they do that?!? This text is going to take me a while to get through if unless my math improves all of a sudden.
I tried \frac{\partial H}{\partial p_\alpha}, and I feel like it yields \frac{1}{2} \sum_{\beta=1}^{3N} G^{-1}_{\alpha\beta}(q_1,...,q_{3N}) p_\beta = \frac{1}{2} \dot{q}_\alpha. This equivalency was defined a bit before in the text, and I guess it makes sense. Partial derivative of H with respect to p_alpha should zero out everything except for the terms with p_alpha. But the factor of 1/2 remains.
I don't even know how to begin to obtain the second equation of motion.I was wondering if a book like this one, https://www.amazon.com/dp/0471198269/?tag=pfamazon01-20, would benefit me?
In my book, he derivation of the Hamilton function starts with defining the generalized momenta, as
p_i = \frac{\partial L}{\partial \dot q_i}.
With that definition, the Euler-Lagrange equations become
\dot p_i = \frac{\partial L}{\partial q_i}
Now you write up dL if t, qi and dot qi change by dt, dqi and d(dot qi). Using
p_i d \dot q_i = d ( p_i \dot q_i )-\dot q_i d p_i
And defining H as
H=\sum{p_i \dot q_i}-L.
The total derivative of H is
dH=-\frac{\partial L}{\partial t}dt - \sum{ \left (\dot p_id q_i - \dot q_i dp_i \right )}.
H is function of time t, and of the generalized coordinates qi and momenta pi. Compared with
dH=\frac{\partial H}{\partial t}dt+ \sum{ \left (\frac{\partial H}{\partial q_i} dq_i+\frac{\partial H}{\partial p_i}dp_i \right )}
you get the equations
\frac{\partial H}{\partial t}= -\frac{\partial L}{\partial t}
\dot q_i= \frac{\partial H}{\partial p_i} and \dot p_i=-\frac{\partial H}{\partial q_i}
For conservative and scleronomic systems, H=T+V.
Likes 1 person
Hi there,
thanks for you reply. I was able to understand your derivation after some studying of it. It does seem that my book offered no indication of this sort of derivation though, which disappoints me.
Note. I wrote above that the Euler-Lagrange in generalized coordinates is:
Which is verbatim from the text.
But it is actually,
\sum_{\beta=1}^{3N} G_{\gamma\beta}(q_1,...,q_{3N})\ddot{q_\beta} + \sum_{\alpha=1}^{3N} \sum_{\beta=1}^{3N} [\frac{\partial G_{\gamma\beta}}{\partial q_\alpha} - \frac{1}{2}\frac{\partial G_{\alpha\beta}}{\partial q_\gamma} ]\dot{q_\alpha}\dot{q_\beta} = -\frac{\partial U}{\partial q_\gamma}
Correction as seen here: http://www.nyu.edu/classes/tuckerman/stat.mechII/StatMech_errata_2nd.pdf
I was too busy reasoning out how the 1/2 term is not present for the first and second terms of the equation that I didn't realize that it was missing in the third term.
zhaos said:
(Euler-lagrange: ##\frac{d}{dt}(\frac{\partial L}{\partial \dot{q_\gamma}}) - \frac{\partial L}{\partial q_\gamma} = 0##)
How did you come to this equation? I derived Euler-Lagrange with Cartesian coordinates (i.e. ##\vec{r_i}##, ##\vec{v_i}##, as showed in that textbook) but there is no clue it should be valid for generalized coordinates ##q_{\gamma}, \dot{q_{\gamma}}##.
