Euler Problem #14: Find Longest Chain <1M
  • Level: Undergrad
  • Thread starter Thread starter ~Death~
    Chain Euler
9 replies · 4K views · last reply
~Death~
im trying to do the Euler problem #14 - to determine which starting value under one million produces the longest chain
and here's my code in Python
Code:
Count=[]
Count2=[]
List=[]
def seq(n):
	if n%2==0:
		return n/2
	else:
		return 3*n+1
m=1
for i in range(1,1000000):
	j=i
	List.append(j)
	while seq(j)>1:
		List.append(seq(j))
		j=seq(j)
	List.append(1)
	Count.append(len(List))
	List=[] #Reset List
	if max(Count)>m:
		m=max(Count)
		Count2.append((m,i))
print Count2[len(Count2)-1]
raw_input("...")
However, I left it on all night and it still did not finish
but it works for lower numbers like for in in range(1,1000) only takes a few seconds
anyone know what my problem is?
Thanks
Mathematics news on Phys.org
Well, one thing is that you're doing 1000 times more iterations through the loop; that adds up fast. Suppose the time per iteration was constant, and 1000 iterations took 15 seconds. Then 15 seconds * 1000 = 4.2 hours.
Another thing is that, on average, a bigger starting number means longer chains -- so the time it takes to do one iteration of your loop is actually increasing, not remaining constant.
By the way, use [code[/color]] ... [/code] tags around your code to format it properly.
Ok thanks Hurkly
im still not sure how to reduce the # of iterations id have to do though
even if I just go
Code:
      print seq(i)
it takes a long time
Displaying stuff to screen is a slow operation. I bet that would only take a second or so if you did something else, like appending seq(i) to a list.
Code:
def seq(n):
	if n%2==0:
		return n/2
	else:
		return 3*n+1
def rec(n):
	while seq(n)>1:
		n=seq(n)
	return n
	rec(i)
raw_input('...')
Even this is still running half an hour later on my computer
and it's the most efficient way I can think of to just run through each chain
so maybe I just have to skip this problem or something if its going to take a day to do
Well, you've checked that you can do 1,000,000 iterations of something simply fairly quickly.
And you've observed that directly computing the length of an entire chain doesn't count as quick.
So, you cannot approach the problem by writing a solution to "find the length of a chain by enumerating it" and then executing that solution 1,000,000 times. You need to do something fundamentally different. For example, in no particular order:
(1) Find some other method of finding the length of an individual chain.
(2) Rather than treating each individual calculation independently, find some way to take advantage of the fact you're really trying to calculate 1,000,000 of them.
(3) Some other clever tweak.
(4) Switch to another programming language and optimize the heck out of the algorithm.
Thanks I got it
Code:
Count=[]
Count2=[]
Count3=[]
Count4=[]
List=[]
Part=[1]
for i in range(1,1001):
	Part.append(i*10000)
def seq(n):
	if n%2==0:
		return n/2
	else:
		return 3*n+1
m=1
for k in range(1,101):
	for i in range(Part[k-1],Part[k]):
		j=i
		List.append(j)
		while seq(j)>1:
			List.append(seq(j))
			j=seq(j)
		List.append(1)
		List=[] #Reset List
		if max(Count)>m:
			m=max(Count)
			Count2.append([m,i])
	Count3.append(Count2[len(Count2)-1])
	Count2=[]
	m=1
	List=[]
	Count=[]
#Sorting
for i in range(1,101):
	Count4.append(Count3[i-1][0])
m=max(Count4)
	if Count3[i-1][0]==m:
		answer=Count3[i-1][1]
		break
print "The starting point that makes the biggest chain is %d"%answer
print Count3
raw_input("...")
it worked I just had to do it in smaller partitions and then clear the lists each time
You may have it working, but it is still not right. From your print statements, I can see you are not using Python version 3.x, but some flavor of version 2.x.
So, you don'r want to use range() for loops that size as it will first create a list that size and then iterate through it. You should use xrange() instead. This will create a generator that will allow you to iterate through it without consuming all that memory.
Wait a moment -- are you saying something is actually wrong, or are you just offering a suggestion for a minor optimization?
If the latter, you're making it sound like a bigger deal than it really is. Yes, xrange is something he should be made aware of, but using range is certainly not incorrect. (And has a very minor effect in this particular case)
Wrong and not right are not necessarily synonymous.
The OP would be better off learning this lesson now while it's minor than having it bite him later. This is the Collatz problem, remember? Where things can get really big, really fast.
