Evaluate 1/(-5x2y3) Answer: Is it Correct?
  • Topic:
  • Thread starter Thread starter mathdrama
    Work
5 replies · 2K views · last reply
mathdrama
I was to evaluate this: (-5x^2y^3)^-2
This is what I came up with:= 1/(-5x2y3) (-5x2y3)
=1/25x4y6
Is this correct?
Mathematics news on Phys.org
=1/25x4y6
Is this correct?
Don't forget to use parentheses and exponent signs. But if 1/25x4y6 is supposed to mean 1/(25x^4y^6) then yes, you are correct.
Assuming this is the same question as yours, below is what i got
(-5x^((2y)^(3)))^(-2)
Expand the exponent (3) to the expression.
(-5x^((2^(3)y^(3))))^(-2)
Cubing a number is the same as multiplying the number by itself 3 times (2*2*2). In this case, 2 cubed is 8.
(-5x^((8y^(3))))^(-2)
Remove the parentheses around the expression 8y^(3).
(-5x^(8y^(3)))^(-2)
Squaring an expression is the same as multiplying the expression by itself 2 times.
(1)/((-5x^(8y^(3)))(-5x^(8y^(3))))
Multiply -5x^(8y^(3)) by -5x^(8y^(3)) to get -5.
(1)/(-5)
Move the minus sign from the denominator to the front of the expression.
-((1)/(5))
Multiply -1 by the (1)/(5) inside the parentheses.
-(1)/(5)
(-5x^(8y^(3)))^(-2)
(1)/(-5)
-((1)/(5))
-(1)/(5)
I believe you have incorrectly interpreted the problem. In any case, your subsequent algebra is flawed, where you state:
=1/25x4y6
Is this correct?
It really helps if you use Latex.
We start with:
$(-5x^2y^3)^{-2}$.
Using the rule:
$(ab)^c = (a^c)(b^c)$
with: $a = -5x^2$ and $b = 2y^3$ and $c = -2$, we get:
$(-5x^2y^3)^{-2} = (-5x^2)^{-2}(y^3)^{-2}$
and applying it again we have $(-5x^2)^{-2} = (-5)^{-2}(x^2)^{-2}$, so the whole thing is:
$= (-5)^{-2}(x^2)^{-2}(y^3)^{-2}$.
Now using the rule:
$(a^b)^c = a^{bc}$ we get:
$ = (-5)^{-2}(x^{-4})(y^{-6})$.
Finally, using the rule:
$a^{-b} = \dfrac{1}{a^b}$ we have our expression is:
$= \dfrac{1}{5^2}\cdot\dfrac{1}{x^4}\cdot\dfrac{1}{y^6} = \dfrac{1}{25x^4y^6}$
As you can see, this is much easier on the eyes than what you posted, although our answers agree.
It's hard to say whether or not this really represents a "simplification", as nothing really "cancelled out".
=1/25x4y6
Is this correct?
There are already a few replies to this. Just thought I would add a slightly different one. Here is how I would do it:
(-5x^2y^3)^{-2} = \frac{1}{(-5x^2y^3)^2}
= \frac{1}{5^2(x^2)^2(y^3)^2}
= \frac{1}{25x^4y^6}
