MHB Evaluate 1/(-5x2y3) Answer: Is it Correct?
  • Thread starter Thread starter mathdrama
    Work
The evaluation of the expression (-5x^2y^3)^-2 leads to the conclusion that it simplifies to 1/(25x^4y^6). Multiple participants confirm that the correct interpretation involves applying exponent rules systematically. The discussion emphasizes the importance of clarity in notation, particularly with parentheses and exponent signs. While some participants present different methods, they arrive at the same final result. Ultimately, the consensus is that the original evaluation is correct, provided the notation is properly understood.
mathdrama
I was to evaluate this: (-5x^2y^3)^-2
This is what I came up with:= 1/(-5x2y3) (-5x2y3)
=1/25x4y6
Is this correct?
Mathematics news on Phys.org
=1/25x4y6
Is this correct?
Don't forget to use parentheses and exponent signs. But if 1/25x4y6 is supposed to mean 1/(25x^4y^6) then yes, you are correct.
Assuming this is the same question as yours, below is what i got
(-5x^((2y)^(3)))^(-2)
Expand the exponent (3) to the expression.
(-5x^((2^(3)y^(3))))^(-2)
Cubing a number is the same as multiplying the number by itself 3 times (2*2*2). In this case, 2 cubed is 8.
(-5x^((8y^(3))))^(-2)
Remove the parentheses around the expression 8y^(3).
(-5x^(8y^(3)))^(-2)
Squaring an expression is the same as multiplying the expression by itself 2 times.
(1)/((-5x^(8y^(3)))(-5x^(8y^(3))))
Multiply -5x^(8y^(3)) by -5x^(8y^(3)) to get -5.
(1)/(-5)
Move the minus sign from the denominator to the front of the expression.
-((1)/(5))
Multiply -1 by the (1)/(5) inside the parentheses.
-(1)/(5)
(-5x^(8y^(3)))^(-2)
(1)/(-5)
-((1)/(5))
-(1)/(5)
I believe you have incorrectly interpreted the problem. In any case, your subsequent algebra is flawed, where you state:
=1/25x4y6
Is this correct?
It really helps if you use Latex.
We start with:
$(-5x^2y^3)^{-2}$.
Using the rule:
$(ab)^c = (a^c)(b^c)$
with: $a = -5x^2$ and $b = 2y^3$ and $c = -2$, we get:
$(-5x^2y^3)^{-2} = (-5x^2)^{-2}(y^3)^{-2}$
and applying it again we have $(-5x^2)^{-2} = (-5)^{-2}(x^2)^{-2}$, so the whole thing is:
$= (-5)^{-2}(x^2)^{-2}(y^3)^{-2}$.
Now using the rule:
$(a^b)^c = a^{bc}$ we get:
$ = (-5)^{-2}(x^{-4})(y^{-6})$.
Finally, using the rule:
$a^{-b} = \dfrac{1}{a^b}$ we have our expression is:
$= \dfrac{1}{5^2}\cdot\dfrac{1}{x^4}\cdot\dfrac{1}{y^6} = \dfrac{1}{25x^4y^6}$
As you can see, this is much easier on the eyes than what you posted, although our answers agree.
It's hard to say whether or not this really represents a "simplification", as nothing really "cancelled out".
=1/25x4y6
Is this correct?
There are already a few replies to this. Just thought I would add a slightly different one. Here is how I would do it:
(-5x^2y^3)^{-2} = \frac{1}{(-5x^2y^3)^2}
= \frac{1}{5^2(x^2)^2(y^3)^2}
= \frac{1}{25x^4y^6}
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
