Evaluate the following integral:
  • Thread starter Synchronised
    Integral
20 replies · 5K views · last reply
Synchronised
Evaluate the following integral using the substitution [tex]u=\frac{1-x}{1+x}[/tex]
[tex]\int_{0}^{1}\frac{ln(1+x)}{1+x^{2}}dx[/tex]
I tried using the given substitution but couldn't do the integral but I did it using [tex]u=tan^{-1}x[/tex] and got the answer = [tex]\frac{\pi ln2}{8}[/tex] so how can I do it with the given substitution?
I tried using the given substitution but couldn't do the integral but I did it using [tex]u=tan^{-1}x[/tex] and got the answer = [tex]\frac{\pi ln2}{8}[/tex] very easily so how can I do it with the given substitution?
Using your substitution, u=tan-1(x), what did you do with the ln(1+x) ?I suspect that there is a typo in that integral . The suggested substitution, [itex]\displaystyle \ \ u=\frac{1-x}{1+x},\ \[/itex] works quite well to evaluate the integral, [itex]\displaystyle \ \ \int_{0}^{1}\frac{\ln(1+x)}{(1+x)^{2}}\,dx\ .[/itex]
No, I am sure there is no typo in the integral.
The way I did it was: [tex]Let u=tan^{-1}x\therefore dx=(1+x^{2})du\therefore\int_{0}^{\frac{\pi }{4}}ln(1+tanu)du=\int_{0}^{\frac{\pi }{4}}ln(1+tanx)dx=\int_{0}^{\frac{\pi }{4}}ln(1+tan(\frac{\pi }{4}-x))dx=[/tex]
[tex]\int_{0}^{\frac{\pi }{4}}ln(1+\frac{tan\frac{\pi }{4}-tanx}{1+tan\frac{\pi }{4}tanx})dx=\int_{0}^{\frac{\pi }{4}}ln(1+\frac{1-tanx}{1+tanx})dx=[/tex]
[tex]\int_{0}^{\frac{\pi }{4}}ln(\frac{2}{1+tanx})dx=\int_{0}^{\frac{\pi }{4}}ln(2)dx-\int_{0}^{\frac{\pi }{4}}ln(1+tanx)dx[/tex]
[tex]\therefore 2\int_{0}^{\frac{\pi }{4}}ln(1+tanx)dx=\int_{0}^{\frac{\pi }{4}}ln(2)dx[/tex]
[tex]\therefore \int_{0}^{\frac{\pi }{4}}ln(1+tanx)dx=\frac{\pi ln2}{8}[/tex]
The integration shown above is correct. I also verified it using Mathematica just in case.
The given substitution does not seem very well to me. Your substitution, to be honest, would be my first try.
But the question says use the given substitution so I don't think I can get full marks if any by using a different substitution in the exam. Maybe the given substitution has something to do with [tex]\int_{0}^{\frac{\pi }{4}}ln(1+\frac{1-tanx}{1+tanx})dx[/tex] ? they look similar.
SammyS said:
You should break that long line further.
That looks better :)
To use the given substitution, just solve u=(1-x)/(1+x) for x. Then substitute that into ln(1+x). Yes, it does look pretty similar.
Ok, thank you :)
[tex]Letu=tan^{-1}x\therefore dx=(1+x^{2})du\therefore\int_{0}^{\frac{\pi }{4}}ln(1+x)du[/tex]
[tex]Let u=\frac{1-x}{1+x}\therefore x=\frac{1-u}{1+u}\therefore \int_{0}^{\frac{\pi }{4}}ln(1+\frac{1-u}{1+u})du...[/tex]
The suggested substitution works perfectly well, when used right at the outset.
Your method has a curious step ...
[itex]\displaystyle \int_{0}^{\pi /4}\ln(1+tanx)dx=\int_{0}^{\pi /4}\ln(1+tan(\frac{\pi }{4}-x))dx[/itex]
Of course, [itex]\displaystyle \ \tan(x)\ne\tan(\pi/4-x)\,,\[/itex] so what gives? This step can be shown to be valid by using the substitution, t = π/4 - x, then changing to variable of integration back to x.
It looks like the sort of trick you might pull to evaluate a definite integral when there is no easy antiderivative. Integrate backwards and apply a trig identity. It's just being clever. Too clever. The given substitution gives you an indefinite integral without the need to resort to tricks like that.
It's just a method to evaluate definite integrals. [tex]\int_{0}^{a}f(x)dx=\int_{0}^{a}f(a-x)dx[/tex] to prove it you just need to use a dummy variable let u=a-x. therefore x=a-u and du=-dx [tex]\therefore \int_{0}^{a}f(x)dx=\int_{a}^{0}f(a-u)(-du)=\int_{0}^{a}f(a-u)(du)=\int_{0}^{a}f(a-x)(dx)[/tex]
Synchronised said:
[tex]u=\frac{1-x}{1+x}\therefore x=\frac{1-u}{1+u}\therefore \int_{0}^{\frac{\pi }{4}}ln(1+\frac{1-u}{1+u})du...[/tex]
I don't get that. I get a factor 1/u in the integrand.
dx = -2(1+u)-2du; (1+x2)-1 = (1+u)2/(4u); (1+x2)-1dx = -du/(2u).
yeah you're right, i still can't evaluate the integral using the given sub from the start...
Synchronised said:
Ok, thank you :)
[tex]Let\ u=tan^{-1}x\therefore dx=(1+x^{2})du\therefore\int_{0}^{\frac{\pi }{4}}ln(1+x)du[/tex]
[tex]Let\ u=\frac{1-x}{1+x}\therefore x=\frac{1-u}{1+u}\therefore \int_{0}^{\frac{\pi }{4}}ln(1+\frac{1-u}{1+u})du...[/tex]
I overlooked the above post earlier.
I hope you didn't mean that your original integral was equivalent to [itex]\displaystyle \ \int_{0}^{\frac{\pi }{4}}ln(1+\frac{1-u}{1+u})du\ .[/itex]
Those are two different substitutions.
Synchronised said:
..., i still can't evaluate the integral using the given sub from the start...
Using the suggested substitution:
[itex]\displaystyle x=\frac{1-u}{1+u}=\frac{2}{1+u}-1\ \[/itex] so that [itex]\displaystyle \ \ x+1=\frac{2}{1+u}\ .[/itex]
Also, [itex]\displaystyle \ \ 1+x^2=1+\left(\frac{1-u}{1+u}\right)^2=\frac{1+u^2}{(1+u)^2}\ .[/itex]
Put that together with what haruspex gave you for dx & see where that all leads you.
Added in Edit:
There is a mistake in my last line. It should be:
[itex]\displaystyle \ \ 1+x^2=1+\left(\frac{1-u}{1+u}\right)^2=2\frac{1+u^2}{(1+u)^2}\ .[/itex]
I get [tex]2\int_{0}^{1}\frac{ln(\frac{2}{1+u})}{1+u^{2}}du[/tex]
So where do I go from here?
Synchronised said:
I get [tex]-2\int_{0}^{1}\frac{ln(\frac{2}{1+u})}{1+u^{2}}du[/tex]
You can write ln(2/(1+u)) a little differently. Then you'll see that one part of the integral looks very like what you started with, but with a constant multiplier.
I almost got it, I get [tex]\int_{0}^{1}\frac{ln(1+x)}{1+x^{2}}dx=\frac{2ln2}{3}\int_{0}^{1}\frac{dx}{1+x^{2}} =\frac{\pi ln2}{6}[/tex] so I made a mistake somewhere :(
what should the divisor be? I keep getting 3.
Edit: It should be 4 but I really can't see the mistake, I checked the signs and everything...
I edited post #14, so divide the above by 2.
That should give you the same answer you originally got.
