Every epsiolon neighborhood is an open set
  • Thread starter Thread starter bobsagat57
    Set
In any metric space, every ε-neighborhood N(P,ε) is definitively an open set. The proof relies on the definition of an open set, which states that a set is open if every point within it is an interior point. By utilizing the triangle inequality, it is established that for any point Q within N(P,ε), there exists a smaller ε-neighborhood around Q that remains entirely within N(P,ε). This confirms that N(P,ε) qualifies as an open set in the context of metric spaces.
  • Understanding of metric spaces and their properties
  • Familiarity with the definition of open sets in topology
  • Knowledge of the triangle inequality in metric spaces
  • Ability to construct ε-neighborhoods around points in a metric space
  • Study the properties of metric spaces, focusing on open and closed sets
  • Learn about the triangle inequality and its applications in proofs
  • Explore examples of ε-neighborhoods in various metric spaces
  • Investigate the relationship between open sets and continuity in topology
Students of mathematics, particularly those studying topology and analysis, as well as educators seeking to clarify concepts related to metric spaces and open sets.
bobsagat57
In any metric space, every ε-neighborhood N(P,ε) is an open set
I'm completely lost on how to start this proof. I considered assuming that there existed a neighborhood that was closed and show by contradiction but from there I was uncertain how to even structure the proof. Any help would be greatly appreciated.
first of all, what is your definition of open set? does N(P,ε) qualify?
(it's probably something along the lines of "a set is open if it contains a neighborhood of each of its points" but you may have some other definition).
An set is open if every point in the set is an interior point.
P in T in an interior point if there exists some ε greater than 0 such that N(P,ε) is an element of T
And yes N(P,ε) is an open set
don't you mean: P in T is an interior point of T if there is SOME ε-neighborhood N(ε,P) that is a SUBSET of T?
it's not kosher to just use N(ε,P) as the ε-neighborhood of an arbitrary point in N(ε,P) (besides the fact that this is circular reasoning).
let me give an example:
suppose we have the metric space R2, with the metric:
d(x,y) = ||y-x||.
one possible ε-neighborhood is D = {(x,y): x2 + y2 < 1},
which is N(1,(0,0)).
well, the point (1/2,1/2) is clearly in D, since (1/2)2+(1/2)2 = 1/4 + 1/4 = 1/2 < 1.
but N(1,(0,0)) isn't centered at (1/2,1/2) it's centered at (0,0). and N(1,(1/2,1/2)) won't work, either, as this isn't entirely contained in D.
Sorry, yes I meant for it to say a subset of T
And if it helps our definition of an epsilon-neighborhood is:
An ε-neighborhood of a point P is N(P,ε) = {Q\inS : d(P,Q) less than ε
Suppose point q is in N(p,\epsilon). Then d(q,p)&lt;\epsilon. Let r= \epsilon- d(q,p)[/itex]. What can you say about N(q,r)?
to amplify, a metric satisfies the triangle inequality. use this fact.
I guess I'm still not understanding what I'm supposed to do, I'm sorry.
the triangle inequality states that for all, x,y,z in the metric space:
d(x,z) ≤ d(x,y) + d(y,z)
suppose x is our point P, and y is our point Q.
N(ε,P) is the set of all points z such that d(P,z) < ε.
HallsofIvy's post says*: suppose d(P,Q) = r.
we know that if we choose z so that d(Q,z) < ε - r, that
d(P,z) ______ by the ______ _______ ,
so z is in N(P,ε), so N(Q,___) is contained in..?
*paraphrasing, slightly different variables used.
so z is in N(ε,P), so N(___,Q) is contained in..?
So, d(P,z) < ε by the triangle inequality, so z is in N(P,ε), so N(Q,ε) is contained in the metric space as well?
Not sure if that is correct, and I'm not sure if I'm seeing how this will help to prove the original problem.
this part is correct.
this makes no sense. in fact, N(Q,ε) usually isn't contained in N(P,ε) (re-read my R2 example).
try drawing a picture. draw a circle centered at P, and draw another point Q. can you draw a circle around Q that is inside your first circle? how does this relate to the general case?
you won't want to use the same epsilon. but you don't have to. you just need to find SOME other epsilon that will work. smaller is better.
Maybe I understand now:
So, given Q\inN(P,ε), let d(P,Q)< r.
Choose z s.t. d(Q,z) < ε - r.
So, d(P,z) ≤ d(P,Q) + d(Q,z) < r + (ε - r) = ε.
Therefore N(Q,ε-r) \subset N(P,ε) and every ε-neighborhood in a metric space is an open set.
Hopefully this is somewhat the right idea.
d(P,Q) is a fixed real number (the "distance" between P and Q). d(P,Q) < r is the wrong way to express this.
why is the set of all such z a neighborhood N(Q,ε') for some ε'? this is not a hard question, but you should be sure you understand this.
see my comments, earlier. you're close.
