Exact Equation with Integrating Factor Help
The discussion revolves around solving the exact equation given by ydx + (2x - yey)dy = 0 using the integrating factor μ(x, y) = y. The user initially attempts to find the function ψ by integrating N with respect to x, which leads to incorrect results. It is clarified that ψ should be derived by integrating N with respect to y instead. The correct approach involves integrating M with respect to x and then adjusting for the function h(y) to find the solution. The conversation emphasizes the importance of the correct integration variable in solving exact equations.
Bogus_Roads
Multiply the given equation by the given integrating factor and solve the exact equation.
ydx+(2x-yey)dy=0, \mu(x,y)=y.
M=y2, N=2xy-y2ey
Integrating N=\Psiy WRT x I get
xy2-((1/3)y3ey + y2ey)+h(x)=\Psi(x,y)
Differentiating \Psi(x,y) WRT x, I get
\Psix=y2+h'(x)
Thus h'(x)=0, and
\Psi(x,y)=xy2-((1/3)y3ey + y2ey)
The correct answer is xy2-(y2-2y+2)ey=c...
What am I doing wrong? When I solve for psi in the opposite way I get the same wrong answer from before...
Thanks in advance!
M=y2, N=2xy-y2ey
But you are looking for a function ψ such that ψx = M and ψy = N.
So to find ψ by integrating ψy = N, you need to integrate both sides with respect to y, not x.
This is my take on this.
Multiplying by the integrating factor gives: y2dx+(2xy-y2ey)dy=0
y2dx/dy+2xy=y2ey
(d/dy)(xy2)=y2ey
Integrate both sides WRT y.
\int \frac{d}{dy}(xy^2)\ dy=\int y^2\,e^y\, dy
So, to do it your way,
Integrate M=y2 WRT x → Ψ(x,y)=xy2+h(y)
 → N=Ψy(x,y) → 2xy+h'(y)=2xy-y2ey
 h'(y) = -y2ey
Integrate this & plug it back into Ψ.
Great, thanks for the help!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
