Examples of closed loop functions
Closed loop functions are defined by pairs of parametric equations, such as x(t) and y(t), where the values at specific points t0 and t1 are equal, indicating a loop. An example is the equation z = x^2 + y^2, which can be represented parametrically as x = sin(t) and y = cos(t). To determine if a function is a closed loop without plotting, one can check if the outputs of the functions at two different inputs are the same. The discussion clarifies that closed loop functions cannot be represented in the form y = f(x) due to multiple values for a single x. Overall, understanding the relationship between the parameters is key to identifying closed loops in functions.
CraigH
Can someone please give me a list of examples of closed loop functions, the only one I know is the equation for a circle
y^2 + x^2 = r^2
Also are there any closed loop functions that aren't multi variable, i.e in the form y=f(x) and not z=f(x,y)
Is there a way to tell that a function is a closed loop without plotting it?
Thanks!
PS, I'm not asking about closed loop integrals here, just functions where the line joins back to itself.
Mathematics news on Phys.org
Not in form of y=f(x), since will be multiple values.
More general is to present it by pair of functions x=x(t), y=y(t)
z=x^2+y^2 may be represented as x=sin(t), y=cos(t)
For any pair of functions x(t) and y(t), with pair of values t0, t1,
such that x(t0)=x(t1) and y(t0)=y(t1),
there is a loop of length t1 - t0
Ah okay thank you, this has cleared a few things up, but what do you mean by:
This confuses me, do you mean y=f(t) and x=f(t)? And what do you mean by pair values?
For example, will take that z=x^2+y^2 <=> x=sin(t), y=cos(t)
Pair of functions: x=sin(t), y=cos(t)
Pair of values: t0=0, t1=2*pi
sin(t0) = sin(0) = 0 = sin(2*pi) = sin(t1)
cos(t0) = cos(0) = 1 = cos(2*pi) = cos(t1)
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 17 ·
