Examples of Separation Axioms
  • Thread starter Thread starter MathematicalPhysicist
    Axioms
The discussion revolves around providing examples of separation axioms in topology. For the first example, the proposed space X as R and subspace A as R-Q is deemed inadequate since the irrationals form a separable subspace of R. The second example involves a function from N to a modified set Y that includes sqrt(2), but there is uncertainty about the countability of bases for Y. The third example remains unresolved, with a suggestion to consider using the same set for both X and Y but applying different topologies. Overall, the conversation emphasizes the need for clarity in defining spaces and their properties in relation to separation axioms.
My assignment is like this:
1.give an example of a space X and a subspace A of X s.t X satisifes Sep and A doesnt.
2.give an example of a continuous and onto function f:X->Y s.t X satisifies S1 but Y doesnt.
3.give an example of a continuous and onto function f:X->Y s.t X satisfies S2 and Y doesnt.
my answers are as follows:
1. X=R A=R-Q, is it a good example?
2.X=N, Y=N-{0}U{sqrt2} and f:X->Y f(x)=x if x in N-{0} and f(x)=sqrt2 if x=0, i think we can't find a countable set of bases for Y, not sure though.
3. didn't do it so far, any hints?
First, what do you mean by "separation"? I would consider all of the "Tychonoff" properties to be "separation" properties: T0: each singleton set is closed; T1: given any two points, there exist a set that contains one of them but not the other; T2 (Hausdorf): Given any two points there exist two disjoint open set such that one contains one point and the other set contains the other point.
Sep says there's a countable dense set.
S1 says there's a countable basis at a point.
S2 says there's a countable basis for the topology.
those should be the countability axioms, sorry for misleading.
"1." isn't good. The irrationals are actually a separable subspace of R (in the usual topology). In fact, if X is a separable metric space, then any subspace of X is separable as well. So your example is going to have to come from a non-metrizable topology.
For 2, what topology are you giving Y?
For 3, I would think about using X=Y, but giving it two topologies, one finer than the other. Then maybe using f=identity.
  • · Replies 20 ·
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 19 ·
