Excel formula =g*(A2^(-1/b)) gives #VALUE error
  • Thread starter Thread starter sara_87
    Excel Formula
13 replies · 5K views
sara_87
I have the formula
S=t^(-1/b)*g
I want to type this into excel.
For S are values typed into the second column (B)
for t are values typed into column A.
I 'named' the b and g using the name manager and set the initial values as 1.
then in the column C i want the predicted values for S so to get the first predicted value, i typed:
=g*(A2^(-1/b))
but i kept getting the #VALUE error and i don't know what's wrong with =g*(A2^(-1/b))
Thank you
That #VALUE can happen when one of the "numbers" is actually text.
A few things to look at are:
What is the value in cell A2?
And, what is the result when you type these formulas:
=g
=b​
It can also happen when the cell isn't wide enough to display the resultant value.
That gives #####, not #VALUE.
Ah, correct you are. However, I was unaware that you could assign values like that in Excel. Whenever I've done that, it's been hardcoded values, or using a locked reference like $A$5 for a value in cell A5 which you don't want automatically incremented by Excel.
EDIT: I think that might be why the OP's thing isn't working: they're trying to assign a value to b somewhere along the line, and then using the letter b in their calculations.
But doing that IS possible in Excel, it just has to be done properly.
Check out Insert-Name-Define for how to assign a cell's value to a variable name.
The value in A" (first value in that column) is 138.
I used the 'name manager' to define g and b.
I defined them then in A10 i put b and in B10 i put 1
then in A11 i put g and in B11 i put 1
(I put 1 because i needed to initialize the b and g) is this wrong?
I used the idea from the website:
http://www.csupomona.edu/~seskandari/documents/Curve_Fitting_William_Lee.pdf
see pages 6 and 7.
then i typed =g*(A2^(-1/b)) and this gave a #VALUE error.
But i don't know why?
see pages 6 and 7.
Well, you are not getting #NAME? errors, so you must have defined g and b to be something.
Make sure g and b are defined to be absolute references (with dollar signs) in the name manager. That's the default. Somehow you are using things that are not numbers.
Here's what I think you are trying to do:
Cheers -- sylas
ok, thanks.
On the excel vista where's the 'solver' tool? i can't seem to find it since it's different to the windows xp.
thanks
Have you installed the Solver add-in? Just having Excel does not necessarily mean you have Solver.
Click on Tools, then Add-Ins. Is the box checked for "Solver"?
but on my excel, there isn't a 'tools' section. there's just:
home, insert, page layout, formulas, data, review, view.
where can i find the add-ins?
thank you
I see. You have Excel 2007, and I have Excel 2003. Things are laid out a lot differently.
Here are instructions for installing Solver:
http://office.microsoft.com/en-us/excel/HP100215701033.aspx
If you get to the part where the Solver box is already checked, that means you already should have it.
An easier (?) way to see if you already have Solver:
"First check whether the Solver is installed on your computer by clicking on 'data' in the menu bar. You will see 'Solver' under data analysis on the right."
(from http://www.familycomputerclub.com/excel/how-to-use-solver-in-excel-2007.html )
Thank you.
I installed it just now.
(I didnt have it before)
