Excel formula to divide column E by column H sums
late347
I have column from E5 -->E35 which contains values for each box.
another column from F5-->F35 contains values for each box
I have a sums column, H5-->H35,, which contains values for the sums between the E and F boxes (E5+F5=H5 ;;; E6+F6=H6 etc...)
I want a division column inside J5-->J35 which contains division such that the dividend = E column and the divisor = H column.
the division should be located inside the J column (J5-->J35) ##J= \frac{E}{E+F}=\frac{E}{H}##
i tried to add function from the "add function" button and "division" but it did not seem to work.
When I drag down the division function, then I only get 1 and 0 as the results of division, even though it is wrong to say that 1/6 = 0
I think I got it done by writing manually into the box what the function would be
1/0's are results of integer type so the cells need to be either float or double formatted.
You can also assign your buttons macros. Something simple like this
JavaScript:
Sub Division()
Dim answer As Double
For i = 5 To 35
    answer = Cells(i, "E").Value / (Cells(i, "E").Value + Cells(i, "F").Value)
    Cells(i, "J").Value = answer
Next i
End Sub
Now you can insert code similarly for H formula.
