Radius of Convergence and Power Series Expansion Around Multiple Values
The discussion centers on the power series expansion of the function \( f(x) = -\sum_{n=1}^{\infty} \frac{x^{n}}{n} \), which converges for \( |z| < 1 \). The radius of convergence is established as 1, derived using the ratio test. Participants clarify that the task involves deriving power series expansions around specific points: -1/2, 1/2, 3/4, and 2, rather than simply evaluating the function at those points. Misunderstandings regarding the application of the ratio test and the nature of series expansions are addressed.
  • Understanding of power series and their convergence properties
  • Familiarity with the ratio test for determining convergence
  • Knowledge of Taylor series and their derivation
  • Proficiency in LaTeX for mathematical notation
  • Study the derivation of Taylor series expansions around various points
  • Learn about the ratio test and its application in determining the radius of convergence
  • Explore examples of power series expansions for functions similar to \( f(x) \)
  • Review LaTeX formatting for clear mathematical representation
Students and educators in calculus, particularly those focusing on power series and their applications, as well as anyone seeking to clarify the concepts of convergence and series expansion.
Philip Land
Suppose we are given the power series expansion ##f(x) = -\sum_{n=1}^{\infty} \frac{x^{n}}{n} ## which converges for |z|<1.
What is the radius of convergence?
Sum this serie and derive a power series expansion for the resulting function around -1/2, 1/2, 3/4 and 2.
[/B]
I can let ##f(x) = \sum_{n=0}^{\infty} \frac{x^{n}+1}{n+1}## so ##f'(x) = x^n = \frac{1}{1-x}## Integrating back gives ##f(x) = -ln(\frac{1}{1-x})=-\sum_{n=1}^{\infty} \frac{x^n}{n} ##
Now I can just plug in the values -1/2, 1/2, 3/4 and 2 right?My question is, why do they ask me to do this with many values if all I need to do is plug it in in the final equation? I think I probably need to do something else/more...
Also, how do I get the radius of convergence? I recall it is 1 in this case, but not how? I've heard I can take the inverse of the results of the ratio test, but that's gives me an expression, ##\frac{x_n}{n+1}## and not a number?
[/B]
NO: ##f'(x) ## is a sum, not a single term. However, ##f'(x) = 1/(1-x)## is correct.
Then ##f(x) = -\ln (1-x),## NOT ##-\ln (1/(1-x)).##
Also note: do not type "ln w" in LaTeX; it produces the ugly result ##ln w##; instead, use LaTeX the way it was designed to be used: type "\ln w" instead. That produces the clear and pleasing result ##\ln w.##
No: the question did not ask for ##f(-1/2)## or ##f(1/2)##, etc. It asked for the series expansions of ##f(x)## about the points ##x = -1/2## or ##x = 1/2##, etc. These would be power series in ##(x+1/2)## or ##(x-1/2)##, etc.
You really do need to read up about and clarify your understanding of "radius of convergence". What does it MEAN if we say that the radius of convergence of a series ##\sum c_n x^n## is ##r > 0?##
Finally: why would you post such a thread in the "Precalculus" forum? It is very definitely a "Calculus and Beyond" question.
The answer to your question is in your original post. You wrote, "derive a power series expansion for the resulting function around -1/2, 1/2, 3/4 and 2."
It sounds like you heard some vague notion that you can use the ratio test to find the radius of convergence, but that's about it. That's a good starting point, but you should read your textbook or notes to sharpen up that notion into what you actually need to do instead of just assuming or guessing.
It seems to me that if you simply slow down and think a bit more carefully, you'll be able to figure this problem out.
You have clearly misunderstood the question. (yes my bad on the misstakes, that should not loose your focus on the key question here).
You pointed out what I don't understand, well why do you think I posted in the forum? Because I understand everything? lol
vela said:
The answer to your question is in your original post. You wrote, "derive a power series expansion for the resulting function around -1/2, 1/2, 3/4 and 2."It sounds like you heard some vague notion that you can use the ratio test to find the radius of convergence, but that's about it. That's a good starting point, but you should read your textbook or notes to sharpen up that notion into what you actually need to do instead of just assuming or guessing.
thanks!
Yes but it's the "expand around a point" part I don't understand. I can derive a general expansion, as done above (with mistakes) but I can't see how that result may differ for different points. I'm new to this and it's not in our book. Is it a straight forward way to explain this?
