- 19,378
- 15,612
Orodruin said:That is not a rate, that is a speed. The distance between two objects 10 Mpc apart grows by 733 km every second.
The discussion centers on the effects of space expansion on galaxy velocities, specifically addressing the Milky Way (MW), galaxy A, and galaxy D. Participants clarify that the expansion of space does not imply galaxies are moving through space at speeds greater than light, but rather that the rate of expansion is characterized by the Hubble constant. The conversation emphasizes that recession velocity increases with distance, governed by Hubble's law, and that General Relativity (GR) adequately explains the dynamics of cosmic expansion and dark energy without necessitating modifications to the theory.
PREREQUISITESAstronomers, astrophysicists, and students of cosmology seeking to deepen their understanding of galaxy dynamics and the expansion of the universe.
And after approximately 30,000,000,000 years (twice the current age of the universe) they will be 20mpc apart and receding at 1466 km / secOrodruin said:That is not a rate, that is a speed. The distance between two objects 10 Mpc apart grows by 733 km every second.
Proper motion.Delta2 said:The velocity due to expansion of space we call it recession velocity. How do we call the "real" velocity due to real motion?
What is the cause of expansion of space and what is the cause of proper motion?phinds said:Proper motion.
If you're going to ask the question, you should wait for an answer instead of indulging in speculation on your own.Delta2 said:here is my take
Well, the point about the universe outside our observable region is that we cannot see or affect it and it cannot see or affect us. So there's a sense in which modelling it is pointless. However, when we assume that the universe is the same everywhere ("spatially isotropic and homogeneous") we get a result that looks very similar to what we see. Occam's razor suggests that we should assume that the rest of the universe that we can't see is the same, because to believe otherwise we'd have to add an unevidenced model of the changes we can't see.Martyn Arthur said:Can we / should we extrapolate that the rate of expansion of space, of a universe that is / may be infinite, is potentially infinite?
You seem to think of the rate of the expansion, i.e. of the Hubble Constant, as of some kind of velocity which increases in an accelerated expanding universe. This isn't the case. Instead in an accelerated expanding universe the HC is decreasing until in the far future it will expand exponentially. Then the HC will have a constant value. This can be seen by checking the Friedmann Equations.Martyn Arthur said:Can we / should we extrapolate that the rate of expansion of space, of a universe that is / may be infinite, is potentially infinite?
Rendered in dimensionless terms, the cosmological constant is an absurdly tiny number (around 10^-120). This is the usual justification.PeterDonis said:Can you be more specific? As I understand it, there are no particular theoretical reasons from within GR itself to think that the value of the cosmological constant we actually measure is too small to be believed; and anthropic arguments (which are admittedly much more speculative) indicate that the value we observe is just small enough to allow us to exist.
The main line of argument I'm aware of that would indicate that the value of the cosmological constant is too small to be believed is that based on quantum field theory, which gives an answer (at least on a certain set of more or less reasonable assumptions) about 120 orders of magnitude larger than the value we observe. But the QFT line of argument itself is based on viewing the "cosmological constant" term in the EFE as not being due to any intrinsic property of spacetime itself (which is what the term "cosmological constant" normally implies), but due to the quantum vacuum having nonzero stress-energy (which would be more aptly described as a theoretical explanation for dark energy).
In GR, the cosmological constant is not dimensionless. It has units of curvature (or energy density, depending on which units you want to use to write the field equation or the Lagrangian). There is no reason in GR to expect that energy density to have any particular value.kimbyd said:Rendered in dimensionless terms
If you really want to take time out from your course syllabus, try this:Martyn Arthur said:The technical understanding of the debate into GR et al is yet beyond my first-year BSc Physics level but that hopefully will come to me.
Just one last layperson question then if I may please, for a first-year physics student's understanding, specifically defined by redshift.
Just basic redshift measurements have identified that galaxies at the perimeter of our visual universe are receding from the Milky Way at circa the speed of light.
Leaving aside the various debates for reasons, could we expect that a galaxy 20 x the perimeter of our visual universe would show a commensurate increase in redshift?
Thanks
Martyn
I'm not a physicist (as will become obvious the more I post here) but I watch a lot of Discovery channel. lol.Ibix said:Well, the point about the universe outside our observable region is that we cannot see or affect it and it cannot see or affect us. So there's a sense in which modelling it is pointless. However, when we assume that the universe is the same everywhere ("spatially isotropic and homogeneous") we get a result that looks very similar to what we see. Occam's razor suggests that we should assume that the rest of the universe that we can't see is the same, because to believe otherwise we'd have to add an unevidenced model of the changes we can't see.
That's not to say scientists don't or shouldn't speculate about other models. But extraordinary claims need extraordinary evidence. There is a significant burden of providing a mechanism by which any such model could be tested, let alone actually testing it.
Why not indeed? This assumption is called the cosmological principle:Dan White said:Why, then would the rest of his universe, unobservable to us, also not be the same?
lol. I guess Isaac Newton got me by about 300 years, not that I really figured it out on my own, anyway.PeroK said:Why not indeed? This assumption is called the cosmological principle:
https://en.wikipedia.org/wiki/Cosmological_principle
Why wouldn't you find galaxies at the edge of our observable universe?Dan White said:Let's say we are looking at a galaxy at the edge of the observable universe (I know you won't find any there,
What I meant is that if you're looking that far away with a telescope then galaxies had not yet formed.PeterDonis said:Why wouldn't you find galaxies at the edge of our observable universe?
You really need to think this through. Having been formed and being visible are TOTALLY different things. Think about what a comoving observer at that location would see vs what we see of that location.Dan White said:What I meant is that if you're looking that far away with a telescope then galaxies had not yet formed.
There's nothing wrong with his thinking that I can see.phinds said:You really need to think this through.
Had not yet formed at the time the light we're seeing now was emitted, yes. But in the rest of your post you're not talking about an observer at that location at the time when that light was emitted. You're talking about some observer there "now", seeing light emitted from whatever existed at our galaxy's location then. And according to our best current model, what that observer would see "now" in light emitted then from our location would be similar to what we see now in light emitted then from their location.Dan White said:What I meant is that if you're looking that far away with a telescope then galaxies had not yet formed.
Well, the phrasing is ambiguous. He got what WE see right but a comoving observer would not see what he seems to think would be seen.Bandersnatch said:There's nothing wrong with his thinking that I can see.
Sorry for confusing everybody. I'm new here and only have a superficial knowledge of this stuff. I signed up here to learn more. I can see that one needs to be precise when commenting here. My original post was like a mixed metaphor. Let me restate so I know I understand correctly:phinds said:Well, the phrasing is ambiguous. He got what WE see right but a comoving observer would not see what he seems to think would be seen.
It's worth mentioning that the farthest back we can see using light is the CMBR (Cosmic Microwave Background Radiation). This is from the earliest time that the conditions in the universe allowed light to propagate effectively indefinitely. Prior to that the universe was so dense that light tended to get absorbed by collisions with elementary particles.Dan White said:Sorry for confusing everybody. I'm new here and only have a superficial knowledge of this stuff. I signed up here to learn more. I can see that one needs to be precise when commenting here. My original post was like a mixed metaphor. Let me restate so I know I understand correctly:
We can view light from the earliest time of the universe because of the distance light has to travel to get to us. There were no galaxies that far back in time so we won't see any, or maybe just proto galaxies. If we now consider present day, that same region is now populated with galaxies, although we won't see them because it takes so long for the light to get here. Also, due to expansion, whatever was in that region billions of years ago is now much farther away. In my original comment I was merely considering two observers, each in their own galaxy, at the edge of each other's observable universe.
Is there something specific about the CMBR that makes it stand out from other radiation that did not originate from the Big Bang? They say something like 1% of the static on your TV comes from the CMBR. How do we know?PeroK said:It's worth mentioning that the farthest back we can see using light is the CMBR (Cosmic Microwave Background Radiation). This is from the earliest time that the conditions in the universe allowed light to propagate effectively indefinitely. Prior to that the universe was so dense that light tended to get absorbed by collisions with elementary particles.
https://en.wikipedia.org/wiki/Cosmic_microwave_background
That said, reasearchers are now trying to detect gravitational waves from even earlier times, as an alternative means of studying the very early universe. Here's something on this from MIT.
https://news.mit.edu/2020/universe-first-gravitational-waves-1209
Yes and no. It's just microwave radiation and totally undistinguished in some senses. However, it's black body radiation at a very nearly constant temperature coming from all parts of the sky. So there's nothing special about the radiation, but the source and the spectrum are fairly distinctive.Dan White said:Is there something specific about the CMBR that makes it stand out from other radiation that did not originate from the Big Bang?
I'd take anything "they" say with a pinch of salt, unless it's backed up by some maths. A quick Google of the frequency of TV frequencies suggests that they are considerably below the peak frequency of the CMB (a few hundred MHz versus 160GHz), but there's some CMB power in the TV bands. I don't know about 1% though - I'd tend to think local interference sources vary wildly in strength so I'd be very suspicious of a blanket figure like that.Dan White said:They say something like 1% of the static on your TV comes from the CMBR. How do we know?
