Expected value of Gaussian distribution with mean dt
5 replies · 5K views · last reply
andresthor
I'm trying to find the expected value of a probability distribution.
[tex]\int_{-\infty}^\infty xP(x,t) = \int_{-\infty}^\infty x \frac{1}{\sqrt{4\pi Dt}}e^{-\frac{(x-dt)^2}{4Dt}}dx[/tex]
I expect the value to be something like $dt$ but then again I might be way off.
I've tried some different substitutions but have had no luck. One example of what I've been trying:
[tex] \begin{equation}<br /> \frac{1}{\sqrt{4\pi Dt}}\int_{-\infty}^\infty x e^{-\frac{(x-dt)^2}{4Dt}}dx=\left/ u=x-dt\right/ = \frac{1}{\sqrt{4\pi Dt}}\int_{-\infty}^\infty (u+dt) e^{-\frac{u^2}{4Dt}}du = \frac{1}{\sqrt{4\pi Dt}}\left(\int_{-\infty}^\infty u e^{-\frac{u^2}{4Dt}}du + dt \int_{-\infty}^\infty e^{-\frac{u^2}{4Dt}}du\right)<br /> \end{equation}[/tex]
But then I get nowhere.
For an integral of the form
[tex]\int xe^{-k(x-a)^2} dx[/tex]
I would write it as
[tex]\int (x-a)e^{-k(x-a)^2} dx+ a\int e^{-k(x-a)^2} dx[/tex]
and try the substitution u = (x-a)2 on the first one. Then you can use the fact that
[tex]\int_{-\infty}^\infty e^{-t^2}\, dt = \sqrt\pi[/tex]
Ok. I gave it another shot but I don't seem to be able to come up with a reasonable solution.
[tex] \begin{equation}<br /> \frac{1}{\sqrt{4\pi Dt}}\int_{-\infty}^\infty x e^{-\frac{(x-t)^2}{4Dt}} dx=\frac{1}{\sqrt{4\pi Dt}} \left( \int_{-\infty}^\infty (x-dt) e^{-\frac{(x-dt)^2}{4Dt}} dx - dt \int_{-\infty}^\infty e^{-\frac{(x-dt)^2}{4Dt}} dx \right) =/u=(x-dt)/ = <br /> \end{equation}[/tex]
[tex] \begin{equation}<br /> \frac{1}{\sqrt{4\pi Dt}} \int_{-\infty}^\infty (u) e^{-\frac{u^2}{4Dt}} dx - \frac{1}{\sqrt{4\pi Dt}} dt \int_{-\infty}^\infty e^{-\frac{(x-dt)^2}{4Dt}} dx<br /> \end{equation}[/tex]
Now I'm pretty sure the right one becomes dt*1, but the other one has me a bit confused. Does the left one equal pi times the constant even though I have 4Dt in the denominator under u?
I'm just completely lost here.
Hint: The integrand of the left integral is an odd function of u. (And the dx should be du.)
In the integral on the left (which should have du instead of dx) try the substitution:
[tex]v = \frac {u^2} {\sqrt{4Dt}}[/tex]
Or you could observe the integrand is an odd function :wink:
Of course! It's an odd function!
Thanks for the help, really appreciated.
