Experimental method to quantify chromatic aberration in telescope optics
  • Level: Undergrad
  • Thread starter Thread starter mishima
    Aberration
2 replies · 1K views · last reply
mishima
Hi, I have 2 similar lens systems used for basic astronomy (as refracting telescopes). The first is a telephoto lens designed for a camera and the second is the main objective of an old pair of binocs paired with an eyepiece in a tube. I am suspecting the former exhibits more chromatic aberration just based on some observations of the moon and bright stars.
I was wondering if there is an experimental setup I could perform, even crudely, on my workbench tabletop that would allow me to compare the chromatic aberrations of both systems quantitatively.
If you have two different colored lasers, you can measure their refraction angles.
As with any optical test, the details matter: image and object distance, field height, f/#... There are two 'flavors' of chromatic aberration- transverse (or lateral) and longitudinal, and these are independent.
Start with the standard spectral lines: 656.3, 587.6, and 486.1 nm. If you don't have access to a 'clean' spectral source, you can probably use a compact fluorescent source. Use of a broadband source (sunlight) will make the measurement more difficult.
The simplest measurement is a 'star test': image a point source and compare the locations of the image at different colors: transverse chromatic will shift the image from side to side, while longitudinal will shift the focal plane along the optical axis. Note that typical chromatic aberrations in a reasonably corrected lens will give displacements on the order of microns. Imaging the 'star' at different field heights and stop sizes will characterize the system.
