Experimental Uncertainty and Error
6 replies · 2K views
jenny777
Hello all,
I used the micrometer in my lab that has a resolution of 100 nm.
so, my measurement looks something like,
0.2345 mm, with an uncertainty of 0.00005 mm.
But I don't want to write, (0.2345 +/- 0.00005)mm in my data table because it just looks a little awkward to have so many zeros inside my table.
Is there a better way of writing the measurement above? (with it's uncertainty)?
Also, I noticed that there are 2 types of error. One is standard error and then the second one being resolution error.
How can I combine the two? so will my resolution error be 50 nm ? I'm subtracting the two measurements to yield delta d, so will my reading error be, sqrt (50^2+50^2)≈71 nm ?
Thank you
jenny777 said:
Hello all,
(0.2345 +/- 0.00005)mm = (234.5 ##\small{\pm}##0.05)μm = (234.5 ##\small{\pm}##0.05)x10-3mm
better? You can put the 10^-3 or the units at the top of the column in the table (as part of the header).
jenny777 said:
Hello all,
Thank you
Use the standard concise notation 0.23450(5) mm where the number in parenthesis is the uncertainty of the last digit of the previous quantity
Shouldn't it be 0.2345(5) mm?
And if I want to write, 666.66 nm +/- 71 nm, how can I represent the uncertainty in parenthesis?
Thank you
No, 0.2345(5) indicates a range from 0.2346 to 0.2344. The actual range is 0.23455 to 0.23445
Thank you
No, 0.2345(5) mm represents (0.2345 +/- 0.0005)mm. You want 0.23450(5) mm which represents (0.2345 +/- 0.00005)mm. Note the extra zero. The number in parenthesis is not an extra digit. It is the uncertainty of the previous digit(s).
666.66(7100) nm = 666.66 nm +/- 71 nm
I would round it to the more practical 667(71) nm. There is no point in using more than 2 significant figures for the error.
