Explain Energy (is it physical)?
65 replies · 10K views · last reply
OmCheeto said:
Entirely? (My motto is "Never say never, and never say always", as there is always some smartypants who will know an exception to the rule)
Now, I do admit to using energy balance almost entirely in my calculations, but I can think of one experiment where force had to be measured. It was to weigh something on a balance scale. I have to go to work soon, so I don't have time to scratch my head and figure out how to describe a balance scale in terms of "energy".
The balance scale does not measure any force. It measures a distance or simply a co-incidence. We infer from some principles that there is a particular measure of force related to the observed distance.
However, we can equally say we measure energy. In a balance scale, that would be the difference of energies stored in the deformed arms of the scale; at any given deformation the scale then seeks the configuration with the minimal potential gravitational energy.
My remark was of a more general nature. It is possible to formulate all of physics without using the concept of force. The Hamiltonian and Lagrangian formulations would exemplify that.
Remind me in my next lifetime, not to be your lab partner.
Om; Ok, step one is we have to measure this on the scale.
Vo; No! We are going to measure its energy.
Om; What?
Vo: Scales are lame. They are interpolations of force.
Om; We only have an hour. What are you proposing?
Vo; We are going to solve the Hamiltonian and Lagrangian formulations.
Om; This is General Physics, and we don't know how to do that here.
Vo; Silence Mortal!
Om; Isn't the balance scale solution just a limit of the frictional coefficient of the fulcrum bearing?
Vo; Silence!
You can be my lab partner Om. We'll grab Phinds as well and several cases of our favorite beverages and measure the energy transfer rate of body heat into cold liquid after consumption. Or if we're too drunk for that there's always drinking songs. I hear Phinds does a wonderful impression of Freddy Mercury singing in a scottish accent after a few drinks...
Drakkith said:
You can be my lab partner Om. We'll grab Phinds as well and several cases of our favorite beverages and measure the energy transfer rate of body heat into cold liquid after consumption. Or if we're too drunk for that their's always drinking songs. I hear Phinds does a wonderful impression of Freddy Mercury singing in a scottish accent after a few drinks...
Go home Drak! You obviously recognize that I'm drunk!
[edit] ps. This morning, I started out with a bathroom scale, but decided, after about 10 seconds of thought, that voko was correct, as the change in my height could be directly correlated to the change in spring energy. Hence, my balance scale.
Indeed. With a spring scale, the energy explanation is obvious. With a balance scale, it is a bit trickier, but it is trickier because a force-based explanation would also be trickier.
I don't see how a force based explanation would be tricky at all.
If I put a penny on each tray of the scale, the force exerted by each penny will be the same, and given my scale has equal length arms, the torque about the fulcrum will be zero, and the scale will be in balance.
And the arms of my scale don't appear to be deforming all that much.
The balance scale actually reminds me of the normal force. N=mg. I suppose I could manipulate that equation and get energy somehow.
hmmm...
I'm just not getting this energy based scale, and I'm late for work again.
ps. 8 old pennies weigh more than 9 new pennies, but less than 10. The fulcrum on my homemade penny scale is a piece of thread, and makes it very sensitive.
why not E = mc2
It gets tricky when the masses are unequal. Explain then why the scale finds some tilted equilibrium rather than rotating all the way till the arms are vertical (or blocked by something).
The simple case of equal masses is just as simple from the energy standpoint: they have equal potential gravitational energies.
This doesn't work as an explanation. An equilibrium position is a position of minimum energy for the whole system, not a position of equal energy for two parts of a system. The minimum energy configuration is with the heavy mass at the bottom, just like with forces.
The equality of masses, the "untilted" equilibrium, and the equality of the potential energies of the masses are all equivalent. If potential energies are not equal, then the equilibrium is tilted, or the system is not in equilibrium at all.
You are using energy concepts completely wrong here. To find the equilibrium position never has anything to do with the equality of GPE of the two masses separately. You look at the system as a whole and find the minimum total energy. That is the equilibrium position. The separate GPE of each side has nothing to do with it.
If you think that my statements in #40 are incorrect, I would like to see some justification, not just something which I find highly subjective. I you so wish, I could provide formal proofs of the statements.
I believe I said quite precisely what the equality of potential energies of the masses on a balance scale has to do with the untilted equilibrium. If you believe that is incorrect, I would like to know why.
It's not tricky, if you consider the geometry of the scale.
The central pivot is higher than the points where the pans hang from the beam.
When the beam tilts, one pan moves further away from the pivot (horizontally) and the other moves closer to the pivot.
The tilted equilibrium position is when the moments of the two weights about the pivot are equal (smaller weight x larger distance = larger weight x smaller distance).
This is not the only possible design of the balance scale.
Consider a balance with raised fulcrum, equal arms, equal chains, and equal pans holding equal masses. The equilibrium position is the one with the minimum total energy, and coincidentally the GPE of the masses on each side is the same.
Now consider a balance with raised fulcrum, equal arms, unequal length (but equal mass) chains, and equal pans holding equal masses. The equilibrium position is again the one with the minimum total energy, and the GPE of each side is unequal since the one on the longer chain is at a lower potential.
Now consider a balance with raised fulcrum, one arm longer than the other, equal chains, and equal pans holding unequal masses that balance. The equilibrium position is once again the one with the minimum total energy, and the GPE of each side is unequal since the larger mass has more GPE.
It is a simple fact which is true of many systems of many different kinds: equilibrium is determined by extremizing the total energy. A stable equilibrium is a minimum, and an unstable equilibrium is a maximum. The equality of the GPE of different parts of a system is a red herring, it is an irrelevant and occasional coincidence rather than the feature which defines equilibrium.
Equal arms, equal chains and equal pans were implicit requirements. Sorry if that was not clear.
I never debated this.
"The equality of the masses of different parts of a system is a red herring, it is an irrelevant and occasional coincidence rather than the feature which defines equilibrium."
True, but how useful in the particular case we are talking about?
Interesting.
An irrelevant conincidence is never useful, just coincidental. Particularly on a forum where we are trying to provide correct and factual information so that people can learn about physics. Physics is about a small set of underlying principles which you can apply to understand many systems, not a long laundry list of random coincidences that can only be applied to one specific system each.
DaleSpam said:
Interesting.
It is entirely possible to build scales that violate this:
"The central pivot is higher than the points where the pans hang from the beam."
yet meet the requirements I listed above.
The purpose of a scale is to measure the equality of mass. Being able to establish the equality of masses, however irrelevant and co-incidental it may be in the grand scheme of things, is all important in this particular domain. I do not understand why you are trying to say it is irrelevant. The equality of associated GPEs is very obviously equivalent.
A few messages ago I stated very explicitly that the minimum of potential energy is what defines the equilibrium. So I am not debating this, and I am not trying to invent some other principle. I am merely stating that as easily as someone can say a scale measures force, one can say it measures energy. Which was, if you look a few further messages back, in the context of my statement that it is possible to do physics without force as a concept.
Yes, the purpose of any balance scale is to measure the mass (not necessarily equality of mass). The equality of GPE of each side is irrelevant and coincidental for only for a specific design, as I showed. The important thing for all balance scales of all designs is that the total energy be minimum at the equilibrium position when the unknown mass is correctly measured.
Then you should have stopped at that point, before you started inventing some other principle. And once it was pointed out that you were inventing some other principle you should have just said "oops" and moved on. This needn't have turned out as the big production that it has.
I agree with that. It is possible to do physics without forces and it is possible to analyze a balance scale in terms of energy. I didn't object to your overall point, only to your description of the equilibrium condition as being due to equality of GPE, which you should have recognized as being a valid objection given your previous comments.
Of course it's possible to build something that way.
Do you have a reference (preferably with a picture or drawing) of a pracitcal balance scale built that way? Unless it has some other clever design features, I think it would be useless because the equilibrium position would be unstable.
Energy in Physics is like money in an economy, but ideal, without forgery and inflation.
Indeed the exchange rate between different currencies can be linked back to the fundamental economic currency that we call energy.
Kind of like the quote in my signature!
Yes, kind of, but without the magic.
I can find no peer reviewed references to OmCheeto. What is it ? Did you invent it ?
You'll have to ask him.
As I said a few messages ago, this principle is far too broad. Many scales will have an equilibrium position when masses are not equal, and many (even though I am tempted to say 'all' here) scales will have an equilibrium position when one mass is too big to be measured, not to mention the infinitely many mechanical systems with some equilibrium which are useless for any practical purpose. You need some additional idea to measure masses.
I do not see any "oops" in what I have said so far and I do not see any other principle. I have merely stated that in a particular scale design, in the context that scales may be interpreted as a contraption for measuring energies rather than forces - which you have agreed with - the equality of masses is equivalent to the equality of their potential energies. I am not claiming any generality of this, yet I find this observation important in the context "balance scales and the force vs energy dilemma".
Your statement was: "The central pivot is higher than the points where the pans hang from the beam."
A scale can have the pivot at the same level or even lower than the points where the pans are attached, and it can have a rigidly attached counter-weight below the pivot, so the entire rotating assembly is T-shaped. This will have stable equilibria within a range of mass deltas.
Let h be the height by which the pan attachment points are elevated above the pivot point. Let H be the distance that the counterweight hangs below the pivot point. Let m be the total mass in the two pans combined. Let M be the mass of the counterweight.
If mh > MH then such an arrangement will not be stable, even when the test masses in the two pans are identical.
Well, technically it will still have a stable equilibrium, but upside down :)
Practically, of course, the counter-weight and the masses will have to be within certain limits for the device to work as intended. That is true for any scale.
I do believe I spend too much time on PF. I had a dream about this thread this morning. Odd thing is, I remember it clearly.
Voko and I were in physics lab, and the instructor placed a rock on the table. He asked us to describe the kinetic and potential energy of the rock, in relation to the table top.
My answers were zero, and, um, zero.
Voko's answer looked like the following: Click to see
I was tempted to reply--"Its a meditating cheetah"--but as I have an extreme sense of propriety and a huge amount of self control I won't.
:p
