Why does integrating dv/v from V1 to V2 give the natural log of V2/V1?
  • Context: High School
  • Thread starter Thread starter jamesd2008
    Intergration
12 replies · 11K views
jamesd2008
Hi
could someone explain to me why, if I integrate dv/v between V2 and V1 the result is nastural log of V2/V1?
Thanks
Is your question why the primitive of 1/v is log v or are you wondering why you get log v2/v1 instead of log v2 - log v1? Anyhow [itex]\log v_2-\log v_1=\log v_2/v_1[/itex].
Yes thanks Cyosis!
Missed the fact that logV2-logV1=LogV2/V1
Thank you very much for your insight!
james
Also is not that 1/v.dv between v2 and v1 = [log|v2|-log|v1|] between v2 and v1? and that the dv is ignored?
The dv is not ignored, it is necessary in an integral to specify the variable of integration.
can you restate this more clearly? I don't get what you are asking.
[tex]\text{By the above phrase I think most people would understand }\int_{v_2}^{v_1}\frac{dv}{v}=log_e(v_1/v_2)\text{ not }log_e(v_2/v_1)\text{.}[/tex]
[tex]\text{Does the use of }|v_1|,|v_2|\text{ here mean that you're interested in values of }v_1\text{ and }v_2\text{ other than positive and real?}[/tex]
Hi, I think what I'm getting confused about, is that for entropy the change in entropy is ds=dQ/T. Integrating this gives s2-s1=the integral of dQ/T between 2 and 1. So are you saying that the change in Q is now just there to specify the variable of integration? Sorry id this all sounds confusing.
It does, apology accepted :)
integral (dv / v) = integral (1/v)*dv = integral (1/v) dv = ln|v|
since our integral is between V2 and V1, we do ln|V2| - ln|V1| = ln|V2/V1|
Martin Rattigan said:
[tex]\text{By the above phrase I think most people would understand }\int_{v_2}^{v_1}\frac{dv}{v}=log_e(v_1/v_2)\text{ not }log_e(v_2/v_1)\text{. ...}[/tex]
[tex]\text{ ... Does the use of }|v_1|,|v_2|\text{ here mean that you're interested in values of }v_1\text{ and }v_2\text{ other than positive and real?}[/tex]
(As before.)
Thanks everyone for there help.
If you integrate from v2 to v1, yes, that is correct. I was under the impression that e was integrating from v1 to v2. The word "between" creates an ambiguity there, I suppose.
