Undergrad Explaining quantum entanglement
Quantum entanglement is often misrepresented by comparing entangled particles to classical objects, which can lead to misunderstandings. While the common explanations may reach correct conclusions about entanglement, they fail to accurately describe the nature of the particles involved. The discussion emphasizes that mathematical formulations, such as using a single formula to describe entangled particles, can clarify the phenomenon, though this approach may be inaccessible to those without a math background. Additionally, it is noted that measurement does not collapse entanglement but rather increases the entanglement with the measurement system. The quality of educational resources on quantum entanglement is also questioned, with a specific video deemed misleading.
davidge
Usually, people trying to explain quantum entanglement, uses the scenario where two particles were created and one of them ends up very far away from the other, and then a measurement is made, etc.
The problem I see is that they seem to assume the two particles are classical particles, like two balls. So the very beggining of the explanation seems to be wrong, for this reason. The following video shows the situation I'm describing here.
But the conclusion emerging from such explanation is correct, namely what Quantum Entaglement causes. So, is that explanation okay even that it describes the form of the particles incorrectly?
For me, it's easiest to explain with math. Not QM math, but regular simple algebra.
If you have two entangled particles, they are described by a single formula: f(x).
Now define one of the particles with a definite value: g(x).
This forces the value of the other particle to be (f-g)(x).
There is nothing else it can be, and no information has to be sent between the particles for it to happen.
Likes sirios and davidge
I totally agree with you.
The problem arises when you try to explain something that only makes sense with mathematics, to people who have not learned the mathematics. In such case, I wonder if it's better not to talk about the given phenomenum at all.
Likes sirios
your its mathematics and good but fails in certain situations of the quantum entanglement, it is worth noting that it is not only the property of spin that interweaves but also others such as the wave function and etc ... as several articles recently published. I think a lot of people get confused in this respect.[emoji5]
Likes newjerseyrunner and davidge
I agree
Likes davidge
What bothers me is, in the video above, she says that "each ball would be red and blue". I believe she should say "each ball COULD be red or blue". But, this may be a philosophical statement, not allowed on a physics forum ... lol
Also, measurement of an entangled pair doesn't really break the entanglement (collapse), it increases the entanglement of the pair with the measurement system. Collapse is just a simplification.
But, I've been wrong often ...
Likes davidge
Normally the channel 'Sixty Symbols' is good, but that particular video is terrible. Don't pay attention to anything it says, particularly the stuff about using entanglement to communicate (i.e. the whole thing).
Likes DrClaude
PF discussion should be based on acceptable sources; the video linked to in the OP is not. Thread closed.
  • · Replies 58 ·
  • · Replies 41 ·
  • · Replies 41 ·
  • · Replies 16 ·
