Explicit formula for the sequence 1, 1, 2, 2, 3, 3, 4, 4,
  • Context: Undergrad
  • Thread starter Thread starter Kopake
    Sequence
14 replies · 4K views
Kopake
I was wondering, is it possible to find an explicit sequence for: 1, 1, 2, 2, 3, 3, 4 ,4 ,5 ,5 ,6 ,6 etc.
without using the greatest integer function, or a recurrency formula? Any help would be appreciated.
Mathematics news on Phys.org
nothing wrong with recurrence, its just that my professor said its possible to find a_n without using it and I can't figure it out
The odd terms are (n+1)/2, n = 1, 3, 5, 7, ...
The even terms are n/2, n = 2, 4, 6, 8, ...
All you have to do is to figure out how to alternate between the two functions and that can be achived by using the alternating (-1)^n
To warm up, figure out how to describe the sequence
a, b, a, b, a, b, a, b, ...
using the alternating (-1)^n.
After you figure that, you can just plug in the two formulas from your original sequence instead of a, b.
oooooooooooooooooooooooooooooo
yep, I'm currently in calc 2, and thanks a bunch smallphi!
both of those series yield even numbers
Eh? Look again.
JohnDuck said:
Eh? Look again.
what? for n=1,3,5,7,9 the first sequence yields even numbers.
for n=2,4,6,8,10 the second sequence yields even numbers?
Sloan's is your friend
Many possibles http://www.research.att.com/~njas/sequences/?q=1%2C1%2C2%2C2%2C3%2C3%2C4%2C4%2C5%2C5%2C6%2C6%2C7%2C7%2C8%2C8&language=english&go=Search"
For the odd numbers:
1 -> (1+1)/2 = 1
3 -> (3+1)/2 = 2
5 -> (5+1)/2 = 3
Even numbers:
2 -> 2/2 = 1
4 -> 4/2 = 2
6 -> 6/2 = 3
Not sure if the floor function is legal for your purposes but if so, this works
m = {1, 2, 3, 4, ...}
[tex]a = \lfloor \frac{m}{2} \rfloor + 1[/tex]
Added later:
Oops! Sorry didn't see this on first read: "without using the greatest integer function"
This works without using the floor or ceil functions
m = {0, 1, 2, 3, ... }
[tex]a = \frac{2 * m + (-1) ^ m - 1}{4}[/tex]
In an earlier post, I came up with this to answer the OP
But I was wondering whether this can be extended to produce sequences with repeating terms of width n? The [tex]-1^m[/tex] trick doesn't seem to help.
It's trivially easy to do it with floor
m = {0, 1, 2, ... }
n = {1, 2, 3, ...}
[tex]a_m = \lfloor \frac{m}{n} \rfloor[/tex]
But what about without floor?
