Explicit variable from equation
4 replies · 3K views · last reply
terminal
hi all!
I'm facing this problem and I can't get a solution, I want to explicit variable m from the following equation, I tried with binomial theorem to break up binomial coefficient but it was useless...
can someone help me please?
[tex]\sum_{i=n}^{n+m}\binom{n+m} {i}p^i(1-p)^{n+m-i} = k[/tex]
all variables are known except m, and k is a known constant.
virtually I'd like something in the form:
[tex]m = g(n,p,k)[/tex]
thanks!
Look at a couple of simple examples. Suppose m= n= 1. Then that says
[tex]\sum_{i=1}^{2}\binom{2}{i}p^i(1-p)^{2-i} = k[/tex]
which is
[tex]\binom{2}{1}p(1- p)+ \binom{2}{2}p^2= 2p- 2p^2+ p^2= 2p- p^2= k[/tex]
In general, that is an m+n degree polynomial in p and you are not going to find any explicit formula for the solution of such a polynomial.
which is
mm let me understand better...you are talking about a polynomial in p, but I told that p is known! my incognita is m... did I miss something?
Sorry, for some reason I thought you had said "p". But because the m occurs both in the binomial coefficient and in the exponent, I would say that there is much less likely to be an explicit formula for m.
mm ok! :)
do you see another way to calculate m (or an approximated value)??
It's ok for me to get the minimum value of m that satisfies:
[tex]g(n,m,p)>=k[/tex]
