Exploring the Pauli Exclusion Principle and Black Holes
The discussion explores the implications of the Pauli exclusion principle in the context of black holes, particularly regarding the behavior of fermions at the event horizon. Participants examine theoretical scenarios involving the interaction of particles as they approach or fall into a black hole, considering both general relativity and quantum mechanics.
  • Some participants propose that if an event horizon is 'full' according to the Pauli exclusion principle, the addition of another fermion could create a conflict, as the event horizon's volume changes with mass.
  • Others argue that infalling objects do not experience a barrier at the event horizon and thus do not violate the exclusion principle, as they pass through without awareness of any perceptual effects observed from outside.
  • A participant mentions that the perception of objects appearing to freeze at the event horizon is an illusion for outside observers, while the infalling object continues to fall without encountering a physical barrier.
  • Some contributions highlight that the Pauli exclusion principle applies outside the event horizon, but its relevance inside remains uncertain, with no established theory addressing it.
  • Participants discuss the relationship between the mass of a black hole and the area of its event horizon, noting that the event horizon expands with the addition of mass.
  • There are claims that the exclusion principle is not violated during the collapse of a white dwarf into a neutron star, as electrons are pushed to higher energy levels rather than occupying the same state.
  • Some participants express skepticism about defining the event horizon as a volume that could become 'full', suggesting that this leads to confusion between quantum mechanics and general relativity.
  • Concerns are raised about whether the event horizon can accommodate additional fermions in smaller black holes due to their higher average density compared to larger black holes.
Participants express multiple competing views regarding the application of the Pauli exclusion principle in the context of black holes, with no consensus reached on how it operates at or inside the event horizon.
There are unresolved questions about the definitions and implications of volume at the event horizon, as well as the interaction of quantum mechanics with general relativity in this context. The discussion reflects a lack of definitive understanding regarding quantum gravity and the states of particles within black holes.
Alfred Cann
The event horizon of a black hole appears to be plastered with 'afterimages' of everything that ever fell into it. (Because gravitational time dilation makes every such object appear to stop at the event horizon.) Now, suppose an event horizon is 'full' as defined by the Pauli exclusion principle. If one more fermion falls into the black hole, would its afterimage violate the exclusion principle?
I think maybe, by the following reasoning. The event horizon radius is proportional to the black hole's mass. If an object of x% of the black hole's mass falls in, the event horizon radius increases by x%. The volume of an infinitesimally thin shell at the event horizon increases by x% cubed.
The volume of an object of a given mass depends on its density, which, for a proton is E18 kg/cubic meter. The average density of the volume inside the event horizon of a one solar mass black hole is 1.85 E19. Thus, in this case, it wouldn't fit, so would try to violate Pauli. What would happen? There are cases where Pauli gets violated, for example, the collapse of a white dwarf to a neutron star. For black holes exceeding about 20 solar masses there would be no problem. Electron density is not well defined, so I don't know what would happen in the case of an electron.
Your comments please.
Astronomy news on Phys.org
I am at a loss to figure how you think the exclusion principle has anything to do with red shifted photons. What am I missing?
phinds,
To an outside observer it looks as if these objects are actually, physically, at the event horizon; not just images. They must, therefore, obey Pauli unless some great force forces them closer.
That is not possible. Infalling objects see no barrier and free fall right past the horizon without even knowing.
The exclusion principle is never violated, even during the collapse of a white dwarf into a neutron star. In this process electrons, which are the dominant particles holding up the star, combine with protons to form neutrons and allow the star to collapse. At no point are particles ever in the exact same state.
The perception of an infalling body 'freezing' at the event horizon for remote observers is purely an illusion. As Drakkith noted, the infaller sails right though unaware of any perceptual illusions suffered by remote observers. To do otherwise suggests a black hole can never actually form.
If you are trying to look at the event horizon as a region with volume -which would be necessary for it to get "full" then how would you define this volume? Pauli is a QM concept and Black Holes are a GR concept so it is not surprising to find some contention when you try to bring them together.
I think this is a bit of an 'Angels on a pinhead' conversation.
Alfred Cann said:
phinds,
As others have now pointed out, you misunderstand what is happening.
The mass of a black hole is proportional to the area (not diameter) of the event horizon. Every time anything falls into a black hole the event horizon gets bigger. Those two things should sort out the mystery. Also, it does not seem necessary to invoke Pauli to consider these questions except that, outside the event horizon, everything must obey the Pauli exclusion principle - I'm not sure anyone has a theory about PEP inside the horizon.
But Pauli only says that Fermions can't share the same energy state. Under those conditions, surely the number of energy states would just go up and become a continuum. That's ignoring anything flashy like GR.
If one more fermion fell into the black hole, the area of the event horizon would increase.
Yes, Papa already pointed this out in post #8, so what's your point?
I'm talking about what an outside observer sees: the object stops at the EH and stays there forever.
Sophie Centaur suggests a good solution: the generation of additional energy levels as needed.
Would you call the different observations of different observers in SR illusions? Then which one is true? No, this is not an illusion; it is reality for an outside observer. Of course, the infaller experiences no barrier.
Good point. I suppose I was assuming a thickness like the diameter of the fermion. But if the thin shell representing the increase of the EH has a volume like that of the infalling fermion, it would obviously be much thinner. I don't understand the rest of your answer. Clearly, I don't know enough.
Wrong. The Schwarzschild (ER) radius is proportional to the mass.
Yes but how much bigger? My concern is whether it's big enough. For a big enough BH it obviously is, because of the low average density. But for a smaller BH it may not be.
You can call it what you'd like. The fact remains that the infalling particle hits nothing at the horizon and the exclusion principle doesn't apply. In fact, I don't think the observer ever actually sees the particle hit anything, so the exclusion principle wouldn't apply even from the observer's frame. The only way for the observer to need to use the PEP is for the particle to actually hit something. As the particle approaches the horizon, I expect that the observer sees it approach, but never hit, the matter that has fallen in before it. However, I admit that I'm not up to speed on the details of SR and GR, so I'd appreciate if someone could verify this for me.
Pauli exclusion principle is not violated when a white dwarf collapses into a neutron star. Rather, the electrons are pushed to higher energy levels. The extra energy comes from a drop in gravitational potential energy. This is only possible if the gravitational field is strong enough, so it puts a limit on the white dwarf mass. The lower energy levels do fill up, but there are always higher energy levels available. A neutron star is held up by neutron degeneracy pressure instead of electron degeneracy pressure, but similar story.
We definitely don't understand quantum gravity yet, so we really can't say anything definitive about the states within a black hole. I'm not sure if fermions exist inside a black hole, because at some point the degeneracy pressure for fermions will be so large that they will spontaneously convert to other forms of energy, such as bosons. Bosons do not have any problem piling up in the same state. However, a black hole has large entropy, so the internal state is probably very complex.
But, under those densities, there would be more and more energy levels available. Pauli is the least of your worries in explaining what goes on under those conditions. It seems to me that the step from everyday QM to QM under strong relativistic conditions is equivalent to the step from Classical atomic theory to QM.
  • · Replies 17 ·
  • · Replies 73 ·
