Express the following statments using quantifiers.
  • Thread starter ayham123
In summary, using quantifiers and primitive operations and relations over natural numbers, we can express the following statements: a) an even number n can be expressed as the sum of four perfect squares, and b) every number n greater than 2 is not divisible by n-1. It is important to note that in this context, we are limited to using {not, implies, or, and} and {+, -, x, >, =}.
ayham123
Express the following statements using { not, implies, or , and} and quantifiers over natural numbers n, we can only use {+,-,x,>,=} as primitive operations and relations over n.
a) even number n is a sum of four perfect squares?
b) every number n greater than 2 is not dividsible by n -1 ?
Did you not read the rules for this forum? You must show your own work, not just ask others to do the problems for you.
i don't know how to solve it! that's why I am asking, i am completely lost
What does it mean to express a statement using quantifiers?
Expressing a statement using quantifiers means to use logical symbols to represent the quantity of elements in a set or the relationship between sets. This allows for a more concise and precise representation of statements.
What are the different types of quantifiers?
The two main types of quantifiers are universal quantifiers and existential quantifiers. Universal quantifiers, denoted by ∀, represent all elements in a set, while existential quantifiers, denoted by ∃, represent at least one element in a set.
How do you use quantifiers in mathematical statements?
Quantifiers are used in mathematical statements to specify the scope of a variable. For example, "For all x, if P(x), then Q(x)" uses a universal quantifier to indicate that the statement applies to all elements in the set of x.
What is the difference between "for all" and "there exists" quantifiers?
The "for all" quantifier, ∀, indicates that a statement is true for every element in a set, while the "there exists" quantifier, ∃, indicates that at least one element in a set satisfies the statement.
How do you negate statements with quantifiers?
To negate a statement with quantifiers, the negation must apply to the entire statement, not just the quantifier. For example, "For all x, if P(x), then Q(x)" would be negated as "There exists an x such that P(x) is true but Q(x) is false."
