Expressing matrices as outer product of two vectors
12 replies · 17K views
mnb96
Hello,
it is known that given two column vectors u and v with N entries, the quantity uvT is a NxN matrix, and such operation is usually called outer product (or tensor product).
My questions are:
1) How can we test whether or not a matrix M is expressible as an outer product of two vectors, that is M=uvT ?
2) Is the identity matrix expressible as an outer product of two (eventually complex) vectors?
Thanks.
I haven't. Although I am familiar with the basics of Clifford algebra, if that can help.
The key to answering both questions it that ##uv^T## is a matrix of rank 1.
OK, since M=uv', and we will take the case of a 3x3 for discussion. Now, there are 9 degrees of freedom (df), in general, for a 3x3, but for two vectors with 3 elements, there are only 6 dfs. So, to be a more useful discussion, let's make the matrix M symmetric and now its has 6 df (down from 9 df), the same dfs as the sum of the vectors. But, for a 4x4 symmetric matrix, there are 10 dfs (4+3+2+1), but the vectors have only a total of 8. Going down, for a 2x2 symmetric matrix, there are 3 dfs (2+1), but the vectors have of a total of 4 df, more than enough(?). Explore the case of a 2X2:
a c = |e |*|g h | = | eg eh |
c d ...|f |.....| fg fh |
Then, a = eg; c =eh=fg; and d = fh.
Let ln(e) = E; ln(f) = F; ln(g) = G and ln(h)= H, ln(a) = A; ln(b) = B; ln(c) = C, ln(d) = D, assuming all logs are defined (??). Then
1*E + 0*F + 1*G + 0* H = A
1*E + 0*F + 0*G + 1* H = C
0*E + 1*F + 1*G + 0* H = C
0*E + 1*F + 0*G + 1* H = D
This system has dimension 3 as upon subtracting the last from the 3rd:
0*E + 0*F + 1*G + -1* H = C-D
and subtracting this from the 1st:
1*E + 0*F + 0*G + 1* H = A-C+D
But this is inconsisent with the 2nd equation:
unless it happens that C = 1/2 (A+D). One can also verify that the original matrix of coefficients cannot be inverted.
Case 3x3
a b c = |g |*|j k l | = | gj gk gl |
b d e ...|h |.....| hj hk hl |
c e f ...|i |...| ij ik il |
So a = gj; b=gk=hj ; c=gl =ij; d =hk; e = hl=ik; f = il.
Let G = ln(g); H = ln(h); etc. and assuming all log transforms are defined(??):
1*G + 0*H + 0*I + 1*J + 0*K + 0*L = A
1*G + 0*H + 0*I + 0*J + 1*K + 0*L = B
0*G + 1*H + 0*I + 1*J + 0*K + 0*L = B
1*G + 0*H + 0*I + 0*J + 0*K + 1*L = C
0*G + 0*H + 1*I + 1*J + 0*K + 0*L = C
0*G + 1*H + 0*I + 0*J + 1*K + 0*L = D
0*G + 1*H + 0*I + 0*J + 0*K + 1*L = E
0*G + 0*H + 1*I + 0*J + 1*K + 0*L = E
0*G + 0*H + 1*I + 0*J + 0*K + 1*L = F
we have a system of equations in 6 variables and 9 equations. We again may not always be able to solve the system in even the 3x3 symmetric matrix case. Forget about higher dimensions.
Look at the various interpretations of the Singular Value Decomposition (SVD) of a matrix. One interpretation of the SVD is that any matrix can be expressed as a linear combination of pairs of matrices of the form [itex]U_i V_i^T[/itex]. The singular values are the coefficients of this linear combination. You are asking when all the singular values are zero except for one of them.
Your counting of degrees of freedom isn't right, because if M = uv' then M = (au)'(v/a) for any nonzero scalar a.
Your idea for finding u and v (if they exist) doesn't work for a 2x2 matrix, or even a symmetric 2x2 where there are 4 terms in the vectors and only 3 DOF in the matrix.
Suppse ##\begin{bmatrix} a \\ b\end{bmatrix} \begin{bmatrix} c & d \end{bmatrix} =
\begin{bmatrix}ac & ad \\ bc & bd \end{bmatrix} = \begin{bmatrix} p & q \\ r & s \end{bmatrix}##.
Ignoring special cases when some matrix entries are zero, from the first row we have
ac = p, ad = q, or c = p/a, d = q/a
From the second row
bc = r, bd = s, or bp/a = r, bq/a = s
So b/a = r/p = s/q
That cannot be satisfied unless r/p = s/q, which means p q r and s can not be four arbitrary values. Making the matrix symmetric, so q = r, doesn't help, because you still need q/p = s/q.
The above applies to every 2x2 submatrix of any size matrix bigger than 1x1.
Note: the result are still true if some of p, q, r and s are zero, the proof is similar but there are too many special cases to write them all out here.
AlephZero:
I fixed my error only to observe you commentary.
My revised conclusion was that the system of equations, even in the 2x2 symmetric case over the set of positive numbers, is generally inconsisent (no solution), which I believe is what your analysis implies also. Note, I say generally, as I may have a identified a very special case in which a solution in the 2x2 case is possible.
Thank you all guys for your advice.
I think that combining all your contributions I can consider my original questions answered.
I will take the risk to go off topic, but I was wondering if it's possible to answer the first question in my original post when instead of having two vectors in ℝn u and v, I have two continuous and integrable functions u(x) and v(x), and instead of the tensor product I consider the 2-dimensional function M(x,y) = u(x)v(y).
When M(x,y) can be expressed as the product of two functions u(x)v(y)?
It's a bit difficult now to talk about SVD and matrix ranks.
Going back to the matrices, you can express any matrix as the sum of k outer products, where k is the rank of the matrix. For example if the matrix has full rank, a trivial solution is to take the u vectors each containing a single entry 1, and the v vectors equal to the rows of the matrix, but this is not a unique solution.
The more interesting version of your questiion is to extend this to an "infinite number of dimensions" and ask whether ##M(x,y)## can be expressed as an infinite sum like
$$M(x,y) = \sum_{i=0}^\infty u_i(x)v_i(y)$$ or $$M(x,y) = \sum_{i=0}^\infty \sum_{j=0}^\infty u_i(x)v_j(y)$$
Note, this does not have the same "trivial" solution as the finite dimension matrix problem, because there are only a countably infinite number of functions being summed, but you want the sum to hold for an uncountably infinite number of values of x and y.
That is s a very general, but interesting question. In view of the counterintuitive possibilities of simply using addition (e.g. the PDF: http://www.google.com/url?sa=t&rct=...sg=AFQjCNF1XfRRDuAqJ6_7C60ttGO81rmoQw&cad=rja) I suppose there is reason to be optimistic about such a representation. I think you must establish a more specific scenario to get answers.
For example if we assume that we can evaluate M(x,y) numerically at the points (0,0) ,(0,1), (1,0), (1,1) then we can get 4 equations for the 4 unknowns u(0),u(1),v(0),v(1). If we can solve those, we have reconstructed u() and v() at those points. If M(x,y) can be evaluated at arbitrary (x,y) (for example, if you know a specific formula for M(x,y), but one that isn't factored), we'd have to think about conditions that guarantee that all the possible simultaneous equations we can set up have some consistent set of answers.
If we assume M(x,y) is differentiable, perhaps we can write differential equations for u(x) and v(y).
I didn't know that the problem I posed is related to Kolmogorov's superposition theorem. Quite an interesting remark.
I agree with Stephen that probably in order to get some answer we must establish a specific scenario. For example I was thinking that if we suppose that [itex]M(x,y)=f(x)g(y)[/itex] and both f and g are integrable and their integral over the reals is not zero, then we have that:
[tex]M_x(x) = \int_{-\infty}^{+\infty}M(x,y)dy = \lambda_g f(x)[/tex]
[tex]M_y(y) = \int_{-\infty}^{+\infty}M(x,y)dx = \lambda_f g(y)[/tex]
where [itex]\lambda_f = \int_{-\infty}^{+\infty} f(x)dx[/itex], and [itex]\lambda_g = \int_{-\infty}^{+\infty} g(y)dy[/itex].
In order words, the projections Mx and My of M onto the x-axis and y-axis are sufficient to reconstruct M (up to a multiplicative scalar). This means that under the aforementioned restrictions on M, a necessary condition for M to be expressible as the product of two one-variable functions is that:
[tex]M(x,y) = k \cdot M_x (x) M_y (y)[/tex]
for some scalar k.
Unfortunately I don't know how to address the case when either one of the projections is zero.
...actually I just realized that there is an easier way to handle the more general case in which none, one, or both the projections are zero.
Considering a function M(x,y) such that there exist at least one point (x0,y0) where the function is non-zero, we assume that:
(1)
[tex]M(x,y)=f(x)g(y)[/tex]
we have that [itex]f(x_0)\neq 0[/itex] and [itex]g(y_0)\neq 0[/itex].
And if we consider the horizontal and vertical slices of M at [itex](x_0, y_0)[/itex]:
[tex]M(x, y_0)=g(y_0)\cdot f(x)[/tex]
[tex]M(x_0, y)=f(x_0)\cdot g(y)[/tex]
we have that:
(2) [tex]M(x,y) = \lambda M(x, y_0)M(x_0, y)[/tex]
for some scalar λ.
It is also possible to verify that [itex](2) \Rightarrow (1)[/itex]. This means that a function M(x,y) that is nonzero at some point, and that is expressible as a product of two functions, can be reconstructed, up to a multiplicative scalar, by the product of the horizontal and vertical slices of M at a point where the function M is non-zero.
This should be also valid for matrices, and it is related to the fact that, as AlephZero has pointed out, such a matrix must have rank=1.
