Expressing moment of inertia in terms of m,a,r and g
The moment of inertia (I) of a platform can be expressed as I = (g/a - 1)mr², where m is the mass, a is the acceleration, r is the radius of the spindle, and g is the acceleration due to gravity. The derivation involves analyzing forces and torques acting on the mass and spindle, specifically using the equations F = ma and t = Iα. The solution requires careful algebraic manipulation of these equations to arrive at the final expression.
  • Understanding of Newton's second law (F = ma)
  • Knowledge of rotational dynamics (t = Iα)
  • Familiarity with torque and its relationship to force
  • Basic algebra for manipulating equations
  • Study the derivation of moment of inertia for various shapes
  • Learn about free-body diagrams and their application in mechanics
  • Explore the relationship between linear acceleration and angular acceleration
  • Investigate the principles of rotational motion and torque
Students studying physics, particularly those focusing on mechanics and rotational dynamics, as well as educators looking for clear examples of moment of inertia derivations.
GMontey
Find an expression for the moment of inertia (I) of the platform in terms of acceleration of the mass (a), the value of the hanging mass (m), the radius of the spindle (r) and the constant (g).
Diagram: http://i.imgur.com/rv3zFYG.jpg
F=ma t=Iα a=rα
Net force: mg-T=ma (T is tension of spring)
Net torque: T-tf=Iα (T is tension of spring, tf is torque)
T=1/2ma
Apparently the answer is: I= (g/a-1)mr^2 but I'm having some trouble getting there.
tension in the what? "string" perhaps?
Net torque: T-tf=Iα
T is not a torque so you cannot subtract a torque from it - dimensions don't match. What is the relationship between torque and force?
T=1/2ma
How did you get that?
You have the right approach - start with free-body diagrams for each element.
But you need to be careful about your math.
i.e. for the mass: +ve = "down": ##mg-T=ma##
i.e. how many torques are acting on the flywheel?
How did you calculate T=1/2ma?
Also note that tf=T*rWELCOME TO PF!
I believe I solved it thanks to all of your help. The forces acting on the mass are gravity (mg) and the tension of the string (T). There is one torque acting on the spindle ( tf). The net torque on the mass is mg - T= ma which can be rewritten as T= mg - ma. The net torque on the spindle is tf =Iα. tf can be rewritten as Txr and I can substitute mg - ma for T, so now I have (mg - ma)xr =Iα. a =αr and I can rearrange this so α =a/r, which I can then substitute into (mg - ma)xr =Iα. Now I have (mg - ma)xr =I(a/r), using some algebra I can rearrange the equation into (mg - ma)xr x(r/a). Now I have (mg - ma)r^2/a, with more algebra I have (mg/a-ma/a)r^2 =I which simplifies to [(mg/a)-m]r^2= I. I pull out m and have (g/a-1)mr^2 =I, please tell me this is right...?
Well done - though it's a little hard to read.
I'd have just left it as $$I=\frac{g-a}{a}mr^2$$ but it is nice if it looks like the model answer.
(you want the mr^2 together because that is the moment of inertia of a point mass...)
Just a tip - it is easier to read your algebra if you lay it out like you would when you write.
i.e give each statement it's own line like this:
T= mg - ma
(mg - ma)xr =Iα.
Now I have
(mg - ma)xr =I(a/r)
... using some algebra I can rearrange the equation into (mg - ma)xr x(r/a).
Now I have
(mg - ma)r^2/a
... with more algebra I have
(mg/a-ma/a)r^2 =I
... which simplifies to
[(mg/a)-m]r^2= I
... I pull out m and have
(g/a-1)mr^2 =I
Huzzah! Thank you very much for both helping me and organizing my mess!
14K
9K
  • · Replies 17 ·
