Extended Comments for Python 3?
  • Context: Python
  • Thread starter Thread starter WWGD
    Python
10 replies · 2K views
Homework Helper
Hi All,
I am having trouble figuring out how to do extended, i.e., many-lined, comments. I know the format is ( copied from website):
Problem is that, while I can find the '' in my Qwerty keyboard, I can't figure out how to find the rest in my keyboard. I assume all Qwertys are the same but if including a pic file of my keyboard helps, please let me know.
TIA.
It should be two keys to the right of the L by using the Shift key.
Thanks, that gives me the " , but not the ones leaning to the other side.
EDIT2: Would a macro that copied the needed image work?
It seems num lock key does it:
They are just straight quotes when you type them. In some programs like Word, they automatically convert to the left and right versions.
It does happen in Word, you're right. But copying and pasting did not work, unfortunately.
If you're copying from Word (or a web page), they've already been changed into something else. You should be able to just put straight quotes in python and have it work.
DrClaude said:
To be clear: you do not want open and close quotes, just simple "straight" double quotes, ASCII 34.
Also true in C, C++, and many other programming languages.
Note also that the use of triple quotes for comments appears to be a trick, not an actual block comment syntax in python: https://stackoverflow.com/questions/7696924/way-to-create-multiline-comments-in-python
Thanks
EDIT: As a demonstration, and to make up for my Noobishness:
def Myfunction():
print('hello')
Nonsense
Myfunction()
Output in IDLE:
RESTART: C:/Users/.../AppData/Local/Programs/Python/Python37-32/Comment.py
hello
My apologies, I was trying what I read online by using just comments, without any code.
