Thermodynamic Properties: Why We Need Them & How to Calculate
  • Thread starter Thread starter manimaran1605
    Properties
Extensive properties in thermodynamics are crucial as they provide insights into the system's overall characteristics, such as mass and volume. Specific values of thermodynamic properties, like specific heat capacity, are essential for calculating energy requirements in processes, such as heating water. Understanding these properties helps in accurately determining how much energy is needed for temperature changes. Density, as an intensive property, remains constant regardless of the amount of substance, exemplified by comparing 1 kg and 2 kg of water at standard atmospheric temperature and pressure. Overall, these properties are fundamental for analyzing and predicting the behavior of thermodynamic systems.
manimaran1605
Why should we bother about Extensive properties in Thermodynamic systems? and
Why do we need specific value of some thermodynamic property? and
what does it tell us about the system? Eg. specific heat capacity?
How density of a thermodynamic system is a intensive property?
It's hard to answer your questions because they are not very specific. What is it exactly you don't understand?
Why not?
Because they characterise the system?
For instance, how can you calculate how much energy is needed to heat one kg of water from 20°C to 30°C if you don't know its heat capacity?
Take two systems, one being 1 kg of water at SATP, the other 2 kg of water at SATP. Is the density different?
Likes 1 person
see: "Extensive Quantities in Thermodynamics" DOI= 10.1088/0143-0807/35/3/035017 (published in 2014)
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 17 ·
