Extracting solution values from Solve rules in Mathematica
  • Topic: Mathematica
  • Thread starter Thread starter Saladsamurai
    Mathematica Rules
8 replies · 3K views · last reply
Saladsamurai
Hi All!
I am trying to get used to Mathematica and rules and all things syntax. What I am trying t do is this:
If I define a variable as such
Code:
m = Solve[x^4 - 4 == 0, x]
The output is:
Code:
{{x -> -Sqrt[2]}, {x -> -I Sqrt[2]}, {x -> I Sqrt[2]}, {x -> Sqrt[2]}}
So I believe what this means is that the variable m now conatins a list of rules for x.
Now if I use the command:
Code:
t = m[[2]]
the output is:
Code:
{x -> -I Sqrt[2]}
which is again a rule. But what if I want, t, to actually take on the value of that solution. That is, I want:
Code:
t [B]=[/B] -I Sqrt[2]
What syntax or command do I need to use to extract this from m?
Thanks!
Surely you know how to apply rules to manipulate expressions. Find an expression you can manipulate to get the solution you want. Then set t equal to that.
Isn't that what I did? Sorry Hurkyl, but your response is kind of cryptic.
DaleSpam said:
t=x/.m[[2]]
Yes. This is what I wanted. But could you elaborate a little on what we just did here DaleSpam?
What is the 'x' for?
Thanks guys!
What sorts of things do you know how to rules? I only know of one: apply the rule to an expression. Your goal, then, is to create an expression that, when the rule is applied to it, results in what you want. (or at least, something you can turn into what you want)
Aside: actually, that's not true. I know three things you can do to rules: pass it to a function like Simplify which will simplify the r.h.s. of the rule, and to manipulate its parse tree -- (x -> a)[[3]] is probably a, but I haven't actually experimented with it to see how this works out.
I don't know, you tell me. You wrote the equation x^4 - 4 == 0 which you solved to get the rule {x -> -I Sqrt[2]}. So what is the 'x' for? It is for whatever you made it for.
If you have the rule {x -> -I Sqrt[2]} and you apply it to an expression that doesn't involve x then it won't do anything.
What I mean is, I don't know what the expression:
t=x/.m[[2]]
is really doing. Could you tell me what the command x/. Is doing in words?
t=x/.m[[2]]
I will try.
The operator /. applies rules to an expression and returns it.
the LHS of /. is an expression, the RHS is a set of rules.
here, the rule is x-> -I Sqrt[2], and the expression is x.
So it replaces x with -I Sqrt[2] which is then returned.
thecritic is correct. The /. operator is short for ReplaceAll[expr,rules]. You can look up ReplaceAll or /. in the online help for more details, but basically it scans through expr looking for anything that looks like any of the rules. If it finds something it makes the substitution indicated in the rule.
