Can space lasers power aircraft with unlimited range?
The discussion centers on the feasibility of using electrically heated thrusters to lift aircraft, specifically a concept where cold air is super-heated and ejected to generate thrust. Participants agree that while the idea resembles an electrically powered jet engine, it has not been realized in practice. The efficiency of traditional motor and propeller systems is noted to be higher, but calculations are necessary to compare the thrust outputs of both systems. Additionally, NASA has explored using laser beams from solar power satellites as a heat source for aircraft engines, potentially enabling unlimited range.
  • Understanding of electric propulsion systems
  • Knowledge of thermodynamics, specifically gas expansion and heating
  • Familiarity with jet engine design principles
  • Awareness of NASA's research on radiant energy conversion
  • Research NASA's studies on laser-powered aircraft engines
  • Explore calculations for thrust generation in electric heating systems
  • Investigate the efficiency metrics of electric motors versus thermal thrusters
  • Learn about hybrid propulsion systems combining turbines and electric heating
Aerospace engineers, propulsion system designers, researchers in renewable energy applications, and anyone interested in advanced aircraft technologies.
GurfX
My knowledge suggests when gasses are heated rapidly, they also expand due to the new energy in the gas.
Is it possible to create a thruster that is able to lift 10kg via electric heating?
The thruster would allow cold air to enter the chamber, where it would then be super-heated & ejected as thrust through a valve.
Let's say the thruster weighs 5kg & it must lift 10kg. Is this possible? i
What you describe is basically an electrically powered jet engine. It's probably possible, but I don't think it has been done before.
Yeah, it would be a fun exercise to calculate the amount of thrust you could get with such an electric super-heater, versus using the same amount of electricity to drive an electric motor and propeller arrangement...
Hahaha I'm not sure if that was sarcastic, but I would like to find out.
No, not meant as sarcasm at all. I'd suspect that the efficiency of the motor+propeller would be much higher, but you'd need to do the calculations to find out for sure.
Well I was thinking of a hybrid concept which uses a propeller/turbine to drive in air through a valve, which would then super-heat the gas & exhaust it.
The propeller/compressor is before the combusion/heating section and the turbine has to be after combustion/heating section. It's a jet engine.
NASA has done work on engines using alternative heat sources. A most interesting application was in aircraft using laser beams from solar power satellites as the heat source for the engine.
The work was summarized in a NASA symposium on radiant energy conversion in space, which sketched out aircraft concepts using space laser power for essentially unlimited range/endurance.
  • · Replies 19 ·
  • · Replies 31 ·
9K
  • · Replies 27 ·
32K
