How Do You Minimize the Sum of One Number and Twice Another Given Their Product?
  • Thread starter Thread starter Nitrate
To minimize the sum of one number and twice another given their product of 200, the relationship xy=200 leads to y=200/x. The expression to minimize becomes s=x+400/x. The derivative ds/dx is calculated, revealing critical points at 0 and 200, with only 200 being relevant due to the domain restriction of positive numbers. A hint suggests that for minimization problems of the form Ax + B/x, the minimum occurs when Ax equals B/x, leading to the conclusion that x should equal the square root of B/A. This approach can be applied broadly in similar optimization problems.
Nitrate
find two positive numbers with product of 200 such that the sum of one number and twice the second number is as small as possible.
2. The attempt at a solution
my work:
xy=200 ==> y = 200/x
x+2y = s (what we need to minimize)
x+2(200/x) =s
x+400x^-1 = s
1-400x^-2 = ds/dx
(x^2-400)/x^2 = dx/dx
(x-200)(x+200)/(x^2) = ds/dx
crit numbers: 0, 200, -200 (not included because the domain is x>0)
my work:
x+2(200/x) =s
x+400x^-1 = s
1-400x^-2 = ds/dx
Are you sure that x^2-400=(x-200)(x+200). What is 200*200??
oh wow >.> what a silly error.
my work:
x+2(200/x) =s
x+400x^-1 = s
1-400x^-2 = ds/dx
Here is a little hint that applies to ANY problem of the form min f(x) = Ax + B/x with A,B>0 (and we want x > 0). At the min, both terms of f are *equal*, so Ax = B/x. That means that x = sqrt(B/A). (Remembering equality of the two terms is easier than remembering the final formula.)
By the way, that "equality" result follows from calculus, but can also be obtained without using calculus---that is the basis of so-called "Geometric Programming".
RGV
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
