Extremely low temperatures at home.
  • Thread starter Thread starter Cryogenics
    Home
Assembling a homemade refrigerator to achieve temperatures below -100°C is possible, but using liquid nitrogen (N2) is a common and effective method. Alternatives like cryocoolers, which consist of a compressor and cold head, can also be utilized, with types including Stirling, Gifford-McMahon, and Pulse Tube. The discussion emphasizes the importance of a vacuum jacketed container to minimize heat transfer when using cryocoolers. While liquid nitrogen is relatively inexpensive and accessible, dry ice can achieve temperatures around -79°C. The user's intent for creating such a refrigeration system remains unclear, raising questions about the purpose behind seeking extreme low temperatures.
Cryogenics
Hi,
i wonder if it is possible to assemble a homemade "refrigerator" to achieve temperatures lower than -100 C ? Any ideas?
Sure. Just get some liquid N2.
Is it possible to accomplish this without liquid N2 ?
Hey there cryogenics. Welcome to the board. Just a couple questions:
- How much money are you willing to spend for this?
- How much refrigeration do you need (ie: in watts)
- Do you have any experience in welding or vacuum technology?
Hi,
1 - don`t worry about the money, anyway we all live in different parts of the world - prices vary.I`m ready to spend.
2 - hell knows, i just need temperatures fall below - 100 C. No need in super power, though, i need something moderate.
3 - No but i have people to help me weld, if needed to. And as for vacuum, well if it is of any importance, i`ve got an oil vacuum pump.
Anyway, sounds like you`ve got a plan:)
I think the best solution is not to make your own device but to use what labs and industry typically uses, a "cryocooler" which generally consist of two parts, a compressor and a "cold head". There are three basic types:
- Sterling
- Gifford-McMahon
- Pulse Tube
You can read about them here:
http://wwwifp.fzk.de/ISAS/statusreport/sr03/Cryocoolers.html
One of the larger manufacturers is Sumitomo. They have their products on line here:
http://www.shicryogenics.com/products/index.jssx
This gives you the ability to cool something down, but the power is fairly low, so you can't have a lot of heat leak into the box you're refrigerating. These units are generally used within vacuum jacketed containers, so you'd need some kind of container to put it in.
One option would be to purchase a liquid nitrogen dewar, they're fairly cheap at a few thousand dollars. The only thing there is that the dewar must have some kind of port on it to insert the cold head in. Another option would be to make your own if you had the expertise.
I don't know of any easy way of cooling something down except to purchase some liquid nitrogen as already suggested and simply dunk it (or hold it above the liquid if you don't want it that cold). Cryocoolers are the primary way of creating your own refrigeration device that can go down to low temperatures.
Q_Goest Thanks! That`s what I was looking for!
Apparently, forgetting Valentine's Day will do the job.
Trust me.
Someone who's username is cryogenics and wonders about how to obtain low temperatures at home makes me wonder. What are you up to cryo?
I wonder how cold something like this could get.
I don't know what you're trying to do, but liquid nitrogen is probably cheaper than anything you're trying to do at home. I'm sure I get some slight institutional discount, but I pay about 50 bucks for 60 gallons. I don't know if they have rules against home deliveries. Dry ice will get you close, around -79 C, and is easy to get.
Yes cryogenics can you please say what you want to do with the cryogenics' cryogenic refigator?It might help if we know what you want to do with.
Note:If you want to put living things in suspended animation don't do it unless to risk hurting what your freezing.
