F(x)=2x + 32/x find the absolute maximum and minimum if they exist
The discussion revolves around finding the absolute maximum and minimum of the function f(x) = 2x + 32/x for x > 0. Participants explore the behavior of the function and its derivatives to determine extremum points.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to find critical points by calculating the first derivative and setting it to zero. They express uncertainty about whether the identified point is a maximum or minimum. Other participants suggest using the second derivative test to classify the critical point and discuss the implications of the interval being open.
Participants are actively engaging with the problem, with some providing guidance on the use of the second derivative test and the nature of absolute versus local extrema. There is a recognition of the need to consider the continuity of the function over the specified interval and the implications for the existence of absolute extrema.
There is a discussion about the continuity of the function on the interval (0, infinity) and the implications for finding absolute extrema, noting that the interval is not compact and thus does not guarantee the existence of absolute maximum or minimum values.
AFNequation
find the absolute maximum and absolute minimum (if any) for the given function :
f(x)= 2x + 32/x ; when x > 0
I tried to solve it but I'm not sure if its a maxima or minima, here are my try :
f(x)= 2x + 32/x
f'(x)= 2-32/x^2
2-32/x^2=0
2u^2=32
u^2=16
u=4 or - 4
-4 is not included cause x > 0
f(4)= 2(4) + 32/4
f(4)= 8 + 8
f(4)= 16
(4, 16) but I'm not sure if it an absolute maximum or minimum?
are my steps correct ?
Find the second derivative at x = 4 to determine if it's a minimum or a maximum. If f''(4) > 0, then it's a local minimum, and if f''(4) < 0 it's a local maximum. Since the only x satisfying x > 0 and f'(x) = 0 is at x = 4, you can tell that it must be an absolute extremum.
thank you
but isn't the second derivative test only to determine the max or min relative ? not absolute extrema?
Yes, but if you find only one local maximum and no other places where f'(x) = 0, it must be an absolute maximum. Try drawing a graph. Draw a local maximum, and try to continue the curve and make it attain another higher maximum. Can you get it to do that without creating a local minimum somewhere?
thanks for your help :)
i got another quistion
do i have to find f(-4) and f''(-4) ? or is it just f(4) and f''(-4) ?
cause it is > o
The problem as given asked for the maximum and minimum of your function for x > 0, so no, you don't need to check x = -4.
f(x)= 2x + 32/x ; when x > 0I tried to solve it but I'm not sure if its a maxima or minima, here are my try :
f(x)= 2x + 32/x
f'(x)= 2-32/x^2
2-32/x^2=0
2u^2=32
u^2=16
u=4 or - 4
f(4)= 2(4) + 32/4
f(4)= 8 + 8
f(4)= 16
Let's take a step back and recall something important.
A function is guaranteed to have an absolute maximum and an absolute minimum on a closed and bounded (aka compact) interval [a,b] if it is continuous everywhere in that interval.
Now, your function is continuous for all x > 0, but you are looking for a maximum and minimum on the interval (0, infinity), and this interval is NOT compact. Therefore the function is NOT guaranteed to have either a maximum or a minimum on that interval!
In fact, it certainly has no absolute maximum: if you plug in increasingly smaller numbers for x, then 2x gets closer and closer to 0, but 32/x gets larger and larger without bound! Similarly, if you pick x larger and larger, 32/x gets closer and closer to zero, but 2x grows without bound. Thus I could make f(x) equal a trillion or a googol or any big number I like if I choose a small enough x or a large enough x.
So at best you can hope to find an absolute minimum.
To verify that an absolute maximum does exist, let's pick x1 and x2 so that
[tex]f(x1) \geq 1000000000000[/tex] for [tex]0 \leq x < x1[/tex] or [tex]x > x2[/tex]
Then [tex][x1,x2][/tex] is a compact interval, and f is continuous at every point in that interval, so it has an absolute minimum (and absolute maximum) when restricted to that interval. As long as the absolute minimum on [tex][x1,x2][/tex] is less than 1000000000000, then it is also the absolute minimum on all of [tex](0,\infty)[/tex].
Since f is also differentiable on all of [tex][x1,x2][/tex], you can now proceed with the usual first and second derivative tests (along with checking the endpoints) to find the absolute max and min on [tex][x1,x2][/tex].
  • · Replies 27 ·
  • · Replies 18 ·
