F(x) = (e^x)/x. at what value of x does f(x) attain its minimum
  • Thread starter Thread starter meredith
    Minimum Value
The function f(x) = (e^x)/x attains its local minimum at x = 1, as determined by setting the first derivative, f'(x), to zero and confirming that the second derivative is positive at this point. However, the discussion reveals a critical point that the function does not have a global minimum; instead, it approaches an infimum of 0 as x approaches negative infinity. The local minimum at x = 1 is the only critical point, but values of f(x) can be less than f(1) for x approaching zero from the left.
  • Understanding of calculus concepts, specifically derivatives and critical points.
  • Familiarity with the product and quotient rules for differentiation.
  • Knowledge of local versus global extrema in mathematical functions.
  • Ability to analyze limits and behavior of functions as they approach infinity.
  • Study the application of the product and quotient rules in calculus.
  • Learn how to identify and classify critical points using the first and second derivative tests.
  • Explore the concept of limits and how they apply to functions approaching infinity.
  • Investigate the differences between local minima and global minima in mathematical analysis.
Students studying calculus, mathematicians analyzing function behavior, and educators teaching optimization techniques in mathematics.
meredith
f(x) = (e^x)/x. at what value of x does f(x) attain its minimum
f'(x) = (x)(e^x) / (e^x)
then do i set both of those to 0 and solve?
how o i do that?
im losttt
Well, that is something you could do, but it would only work if your derivative is correct and I don't think that it is.
That's not the derivative. To get the derivative you need to use the product (or quotient) rule:
(fg)' = fg' + gf'
This equals e^x/x - e^x/x^2 = (e^x/x)(1-1/x)
You need to set this equal to 0 and solve for x to find the critical points of f. To find all local minima, find all points for which the 2nd derivative is positive. To find the minimum, you need to compare all the values of the local minima and take the smallest one. You also need to look at boundary points, which in our case would be +infinity and -infinity.
This problem's solution is easy to see since there is only one critical point.
at x=1 we would have the minimum
because x=1 is the only critical point after we equate first derivative =0
and second derivative is>0 at x=1 so minima occurs
"at x=1 we would have the minimum
and second derivative is>0 at x=1 so minima occurs "
I believe this answer is incorrect, if one answers the specific question the OP is asking. I can throw out a value of x where the f(x) < f(1).
Your answer may be right, if one means to talk about local extrema.
csprof is right. It's a stupid question, because there is no minimum (by definition - either the authors didn't understand this or they did this as a trick question). The infimum is 0, which occurs at x=-infinity. There is no minimum. The only local minimum is at x=1.
What about x = -0.000000000001? exp(x) ~ 1 and 1/x = -1,000,000,000,000. Looks like f(-0.000000000001) < f(1) < lim f(x) as x -> -inf.
phreak said local minimum. x= -0.00000000001 is not vry "local" to 1!
I wasn't taking issue with his statement regarding the local minimum... just pointing out that, as should be clear to everyone, the function goes to -infinity as x approaches zero from below.
  • · Replies 18 ·
