Factor Expression: A2+B2 from 3[√3+√5+√7]2
  • Thread starter Thread starter cupcakes
    Expression
9 replies · 3K views
cupcakes
Express the following as A2+B2:
3[√3+√5+√7]2
I expanded it to 45 + 6√15 + 6√21 + 6√35
Should I collect like terms (the multiples of 6)? I don't know how to proceed from here. Thanks in advance for any help.
I'm not sure, but I don't think this expression can be converted to the form A2+B2.
Maybe it's because I forgot to mention that A & B may contain roots. I think it's possible because it is an assigned question. But I'm stuck...
There are no real numbers that factor to the sum of two squares. Your answer will be imaginary.
3[√3+√5+√7]^2
3[√(1.5)+√(2.5)+√(3.5)]^2 + 3[√(1.5)+√(2.5)+√(3.5)]^2
up in the middle of the night doing this.. so I may have broken a million rules getting to this point :blushing:
You Might want to double check but they seem equivalent :devil:
How about this?
3[√3+√5+√7]2 = 2[√3+√5+√7]2 + [√3+√5+√7]2
The original expression is now written as a sum of two terms. Can you finish the problem by showing that each of these terms is the square of something? I.e., can you identify A and B with the above being equal to A2 + B2?
It only works with odd numbers
(√1.5 + √3.5)2 + (√1.5 + √3.5)2 = (√3 + √7)2
The left side is 2 * 9.58 = 19.16. The right side is 19.16(√44.5 + √6.5)2 + (√44.5 + √6.5)2 = (√89 + √13)2
The left side is 2 * 85.014 = 170.029. The right side is 170.029
yesh?
yesh?
Yes, this works. My example (now deleted) was flawed in that I forgot to square the value on the right side. Apologies for the misdirection...
Here's what's going on.
(√1.5 + √3.5)2 + (√1.5 + √3.5)2 = 2(√1.5 + √3.5)2
= (√2 *√1.5 + √2 *√3.5)2
= (√3 + √7)2
Mark44 said:
How about this?
Hey no worries, Mark44, beside I found my version of the solution completely out of luck just bored and messing around with my calculator :P
You're version of the sum of two terms is just as valid isn't it?
Mark44 said:
How about this?
How did I not notice that?! :smile: That works perfectly Mark. Thanks to everyone for their help.
